Page 291 of 939 FirstFirst ... 191241281287288289290291292293294295301341391 ... LastLast
Results 2,901 to 2,910 of 9388
    #2901
    he's based in angeles but he always comes here in manila..I met the guy, he's nice & accomodating.. No problem the way he installed my 3 sets of HID's..He had installed his HID brands to a lot of Montero Sport's as you can see on his gallery aside from the other MS he installed last year.. I've been using my HID's for 6 months already, Ive even used it on a stormy weather 7 hour long drive but never encountered any moisture on my headlights & fog lamps..
    He was the one also who recommended that i use 6000K's on hi/lo beam for better visibilty during long drive..3000K for fog lights para di hirap during rainy/foggy weather..
    sir JPG111,
    magkano inabot lahat yung hi, lo & fog lights HID mo? paki pm naman yung name at contact number ng supplier. thanks...
    best regards,
    howie
    Aug 2008
    #2902
    mayor, pareho lang pala ng bulb ang reverse light and signal light sa front... I changed all my signal lights to white, and I used the same brand...
    question lang sir, how did you change the bulb for the reverse light?
    Oct 2003
    #2903
    Quote Originally Posted by migs0624 View Post
    I suggest you get the 22s na. I've tried fitting the 20s na chrome.
    no offense sa mga naka 20s dito, pero medyo bitin sya talaga.
    pero 20s na hindi chrome, siguro ok lang.
    but if chrome's talaga gusto mo. get the 22s or better yet 24s
    20s prep 100-120k
    22s prep 150-200k
    24s i have no idea, cant afford these
    those are black rhino with nitto tires.
    hope this helps you out man. good luck.
    sir migs,
    thanks for the info. saan shop po ba ang recommended na maraming mapagpipilian na rims? i may be staying a day or two in manila before heading home, so i need to be precise where to go and save time.
    Apr 2009
    #2904
    Quote Originally Posted by WenG2 View Post
    sir migs,
    sa greenhills. wheel gallery.
    Aug 2008
    #2905
    Are you sure its only 24 watts?, go check it again..
    Di nakakasilaw not because the HID's are not bright but because the projectors are well pointed & focused on the road..Im satisfied with the kind of brand i installed.. I dont see it as for looks only coz the HID's i choose really serves its purpose & not just for those " pasikat " on the road.. And im sure my HID's can also light up what the expensive brands can do..Kanya kanyang choice lng yan fanboi :badboy:
    I also installed LXSUN in my MS, 8000k low beam and 6000k fogs... i've been using it for 5 months now.. so far i have no complaints... also, i haven't experienced another car on the other side of the road flashing his lights because of the glare from my HIDs...
    Apr 2006
    #2906
    Quote Originally Posted by gabrcri View Post
    sir its easy to change the bulb of the reverse light, dukutin mo lang sa back part ng reverse lens sa bumper
    May 2009
    #2907
    hi,
    i am about to get a montero sport 4x2, my concern is will the 2.5 engine be some what under power? and another one is the resale value. I haven't seen this brought up this in thread so far.
    thanks.
    Oct 2007
    #2908
    sir kasama ba manual ng Code Alarm mo? if model CSI-300 nasa page 6.
    1. From the disarmed condition, turn the ignition key to the on position.
    2. Press and hold the valet push-button switch until the das mounted LED turns on. The LED will remain on as long as the system is in valet mode.
    3. To return to normal operation, press and release the push button switch anytime the ignition is on.
    thanks sir XTO. yes the manual is included and i've read it pero which one is the valet button switch? my remote has 4 buttons... the lock, unlock, trunk, and the asterisk. am i missing another button? pardon my ignorance hehehe.
    Oct 2007
    #2909
    hi! another inquiry po... is it possible to install a rear foglamp on my 4x2? how much would it cost and where? thank you!
    #2910
    Quote Originally Posted by Howie View Post
    sir JPG111,
    best regards,
    howie
    salamat po sa info sir JPG111....
    best regards,
    howie
