Results 1 to 9 of 9
- Sep 2006
- 84
June 14th, 2008 05:55 AM #1Hi mga Mitsu Gurus, ask ko lang which is better in performance on the latest Mitsu engines : MIVEC (Mitsubishi Innovative Valve Timing Electronic Control) or GDI (Gasoline Direct Injection) assuming the same engine displacement.
June 14th, 2008 08:20 AM #2
mivec - up to 7500/8000 rpm.. much better than vtec.
gdi more on fuel economy
June 14th, 2008 02:34 PM #3
MMC is no longer focusing on GDI engines due to its lack of compatbility with various fuel requirements. it is either because of MMC lack of research or lack of capital to reaserch further. it would have been nice as this will aid in fuel economy. also other car brands have been successful with this- like Audi for example. GDI focuses on fuel delivery that directly sends fuel to the combustion chamber.
MIVEC is the other way around. its compatibility reached more countries including the US and the Philippines to name a few. MIVEC's approach is different as this focuses more on today's trend of Variable Valve Timing that will aide fuel economy (example: 4G64 vs 4G69 ad 4B12)
It is up to MMC now to create an engine combo of MIVEC+GDI to create a truly eco friendly yet power oriented engine. If ever they did, then I'm sure they are finalizing it. Good luck to MMC
- Sep 2006
- 84
June 14th, 2008 03:19 PM #4It is up to MMC now to create an engine combo of MIVEC+GDI to create a truly eco friendly yet power oriented engine. If ever they did, then I'm sure they are finalizing it. Good luck to MMC
MIVEC+GDIWOW! ang galing..hope MMC will develop this engine.
Thanks for the replies!
June 17th, 2008 03:15 PM #6
Meron ding nilabas na MIVEC na matipid sa gas compared to the usual MIVEC engine.
Source: http://en.wikipedia.org/wiki/MIVEC
MIVEC-MD
In the early years of developing its MIVEC technology, Mitsubishi also introduced a variant dubbed MIVEC-MD (Modulated Displacement), a form of variable displacement. Under a light throttle load, the intake and exhaust valves in two of the cylinders would remain closed, and the reduced pumping losses gave a claimed 10–20 percent improvement in fuel economy. Modulated Displacement was dropped around 1996.
June 18th, 2008 05:59 AM #7
Yup, same yung MIVEC-MD sa VCM ng Honda. But still, nawala sya.
iam3739.com
- Jun 2008
- 6
August 4th, 2008 07:15 PM #8
August 4th, 2008 09:13 PM #9
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
