Results 41 to 50 of 51
February 22nd, 2009 01:04 PM #41
I think it's true for all. Sa akin ma-usok din...but they say it's normal daw bec. of the humidity kasi. But it varies din ha...baka problem talaga (like sparks, fuel, oil etc.) . But you can search the other galant forums
CLUBVR4.COM (Europe based -UK, NZ etc. -first forums na nasalihan ko!)
GALANTFORUMS.COM (ok dito lotsa pimping!!)
OZVR4.COM (Australian based)
THEGALANTCENTER.NET
MYMITSUPH.COM (RP based -I think may problem sya! I can't register)
and u'll see it is common but not much to worry about. Pasado naman sa SMoke Emission eh
February 23rd, 2009 10:08 PM #42
mga sir, tanong lang sana... we are in a search for an engine swap with our VR4 . ill just ask sana where are the place/s that have reliable VR4/VR6 engines and estimated cost.
thanks in advance.
- Mar 2009
- 1
March 5th, 2009 02:07 AM #43sir, pasingit po, tanong ko lang po sana if alin ang mas magandang bilhin, galant VR6 or VR4 considering na i am only a student?
please help me on this matter. tnx.
Tsikot Member Rank 3
- Jul 2004
- 1,540
March 5th, 2009 02:23 AM #44As far as I know walang VR4? Or JDM model yan?
For the 7th Gen Galants, I think there are two variants.
The V6 engined VR model and the 4 cylinder Super Saloon, I think both have manual and automatic options.
For the 8th Gen same din ata except that the VR came with automatic lang.
Not 100% sure on this though. Mga 95% sure. hehehe
I drove a 7th gen VR manual when I was a student. If fuel consumption is one of your concerns just get something else, I was getting 5-6km/l ata. For me sakto lang yun. hehehehe
March 10th, 2009 07:29 PM #46
i have a '95 galant VR V6..thank God it doesnt give me any headache. Gas consumption is justified by the power & speed.
Masasabi ko lang sa galant VR..di ka basta basta masisibak sa kalye pag eto oto mo...its not just fast, but its very quick, bawat tapak mo sa gas, it push you back to your seat
March 12th, 2009 05:40 PM #47
same here, got no problems with my wheels and i'm talking of a 21 year old car (galant 88), first generation of galant front wheel drive, 1.8, evolving from the box type. carburator, imported.
I dont think it's the age but the proper maintenance. Old cars are built to be maintained by the owners, later versions (perhaps 92 up) are built to be maintained by the dealers. That's business bros...
- Jul 2009
- 6
July 22nd, 2009 10:51 PM #48Hi guys..i am new member of this site.hahaha.i've got my first car which i purchased from my friend.hahaha.ang lakas sa gas pero swabe naman tumakbo.saka super pogi. sana magkaron ng mitsu galant club para nmn may mapagtanungan kung may prob sa mitsu galant ko..tnx guys.
- Jul 2009
- 6
July 22nd, 2009 10:55 PM #49tol parehas tayo ng car.suave tumakbo matanda na yung car but still well-maintained sya.malakas aircon.suave ang hatak ganda ng body at walang kalampag.basta hinay hinay lng ng gamit ang ganda pa.tama justified yung gas consumption sa lakas ng power.
- Jul 2009
- 6
July 27th, 2009 01:27 AM #50i maintain my Aunts dark gray '94 Mitsu Galant Super Saloon M/T acquired last Feb.2002, odo reads 74k and had it shipped to bacolod. it's already partly dressed up; side skirts, front chin,bumper curb lights, rear spoilers, power folding side mirrors, 15" Concept-Seven Katana alloy wheels, 195/60 Bridgestone Turanzas...
only a cracked radiator spoiled it 6 months later. i just replaced it with a surplus '89 Galant (P4,500)...same width but a little taller (the nearest spec, '98 Lancer A/T , P11,000...too pricey). though some cuttings on the rubber supports and relocating the upper brackets (no welding, no drilling)can clear it from the hood.
in 2005, i replaced the front left upper-arm ball-joint(bog-bog sound), 2 rear and 2 front anti-roll bar links (since they are reasonably priced), all the brake disc pads (L-300 on the front will do), fuel filter and the Battery, of course.
two years ago, the alternator went dead. i had it repaired by a technician/friend but it didn't last. it's the still the stock, boxy, 75Amp and no replacements can be found here... so, ask the experts. a parts supplier recommends a rebuilt Hyundai Sonata alternator, same bracket attachments, same 4pk pulleys, but chunkier body and....90 AMPS!!!(nearest spec '98 Pajero 2800,just swap the pulleys) since i have bigger amperage now, i retro-fitted headlights with 100/90 watt Narva's, main beams and curb lights with 100 watt Hella's (although i don't recommend these to you, it's too much, a set of 100/80's will do...the rest are stock 55 watts). a blueish white smoke at the exhaust at wide open throttle starts to appear
last year (april, 2009), it undergoes a make-over. we had it painted medium silver (extra-course) metallic Anzhal's, the wheels were coated with slightly metallic black and brandywine overcoat, all in Timeless' topcoat. body-color brake brackets and 888 red brake calipers, great for a coca-cola-bodied car.
as in most mitsu's i've encountered, the valve seals always hardens. i opted for a top overhaul instead of a general one since minimal crankcase pressure was observed. i cleaned the cylinder head and rocker assembly myself...changed both timing and balancer belts as well (150+k kms), right side main engine support, original NGK spark plugs. i use Mobil XHS engine oil and Vic oil filters.
top speed is still 150 kmh...not enough long roads here. even though i don't have enough supercar acceleration (the idle control is busted since bought) the mileage is a lean 7-9 km/l city and 11-15 km/l on highways (just be easy on the pedals always)...and she drives it almost everyday and me on out-of-town drives.
IMO, it's about knowing the car and TLC treatment, regardless of brand...and the toyota vios is not an M-size car (LTO)...please don't compare them.
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
