Page 183 of 209 FirstFirst ... 83133173179180181182183184185186187193 ... LastLast
Results 1,821 to 1,830 of 2090
    #1821
    Try nissan livina sir if you can wait... it’s coming soon... 99% the same sa xpander...
    but will it have a different engine?
    As per the specs, yes.
    Quote Originally Posted by gmotu View Post
    After over 4 months with the Xpander, I'm still happy with everything except for fuel economy.
    I thought it would fare better in Manila traffic compared to crossovers and bigger cars but it just goes 6km/l in Manila, comparable to my brother's Subaru XV and my other brother's old Camry. My Strada did better at 8km/l. Everything else is great though. Would consider getting another to replace another aging car but Autodeal says the price increased by over 100k. Crazy.
    if fuel consumption is a concern, ertiga 1.5 is a little better with its lighter overall weight.
    #1824
    how much better?
    #1825
    what's your usual travel distance and how long does it take?
    how much better?
    its a plus 0.5-2kml
    smaller engine 1.46L vs 1.499L
    higher compression ratio
    slimmer tires
    lighter kerb weight.
    lower ground clearance
    shorter gearing of the transmission.
    Jul 2015
    #1827
    For a 1.5L engine and a heavy body, you need to rev it to get decent power, peak torque is at 4000rpm..that why the lackluster FC, kung hiway cruiser..no issues yan..
    Quote Originally Posted by yohann012 View Post
    Good day mga boss.
    nandto lng po ako para humingi ng advice
    i have my lancer 1993 EL
    pero my problema ako tungkol sa oil leak .
    una nilagyan nila ng seal yung bilog sa ilalim ng engine tapos ngayon lalong lumakas yung oil leak sabi nmn nila sa transmission na daw po ang lalagyan nila ng seal tama po ba yun o kailangan ko na syang palitan ng makina . sobrang low budget mga sir .sana matulungan nyo ko
    Usually oil seal or gasket lang talaga ang pinapalitan pag may mga oil leak... pero if yung leak is parang tagas na baka may serious issue yan sir... You can identify if transmission ba siya or hindi by tracing where the oil leak came from...
    #1829
    as ray above says,
    it's usually just an oil seal or a gasket.
    but replacing it can get tedious.
    it's probably another example of the cost of labor being much more than the cost of the part to be replaced.
    pictures would be nice...
    Jun 2005
    #1830
    Expander topic pero oil seal ng lancer amg tanong
    Sent from my MI MAX 2 using Tapatalk
All new Mitsubishi Expander MPV!
