Results 1,721 to 1,730 of 2090
November 9th, 2018 02:08 PM #1721
November 9th, 2018 02:17 PM #1722
Yes, I did pass by the old road going to Bicol. There are certainly some steep segments there but not as lengthy as can be found at Kennon, just before and after the Lion's head. Yun eh kung bukas ang Kennon...
Though I believe the Xpander can handle that just as easily as it did in Quezon, but I need to test downshifting manually to L2 and L1 to see how she goes. After that, I'll have gotten the car through all the paces I need her to excel in.
November 9th, 2018 02:17 PM #1723
- Aug 2017
- 870
November 9th, 2018 02:46 PM #1724Kenon is closed to heavy vehicles, only light vehicles are permitted but that is only limited to the residence of the said place. There's a bridge under repair and only alternative bridge to pass thru.few falling rocks on the roads.
What I do is going down from baguio via Kenon, take some pictures sa lion. Then push thru going down till reach the toll station then stop by security and ask you where to go(if you're residence). Try to please the security to allow you to pass and you need to write your name and plate number sa log book. Took me 20min till reach Rosario junction.
Note: please be cautious if you want to take the risk.
Sent from my Pocophone using Tapatalk
- Aug 2016
- 62
November 9th, 2018 11:59 PM #1726eto lang po so far ang info ko, as of current pricing:
1K / 5K kms
FREE LABOR
oil filter P383.00
gasket 48.00
sticker radiator cap 8.00
engine oil 1395 semi-synth / 3020 full synth
misc 280.00
fuel treatment 330.00
total P2444.00 (semi) / P4069.00 (full)
REGULAR CHECKUP
10K / 30K / 50K / 70K / 90K kms
LABOR P3515.44
wheel balancing 550
.. everything above PLUS
engine flush P300
car care kit 350
oil treatment 995
windshield washer fluid 150
total P8304.44 (semi) / P9929.44 (full)
LIGHT CHECKUP
15K / 35K /45K / 55K / 65K / 75K / 85K / 95K kms
everything above MINUS wheel balancing *P550 and slightly cheaper labor * P3161.24
P7400.24 (semi) / P9025.24 (full)
HEAVY CHECKUP
20K kms/ 40K / 60K / 80K / 100K kms
everything in REGULAR CHECKUP PLUS slightly higher labor P4374.37, air cleaner P1607.08, spark plugs P4380.00, coolant P1215.00 (40K and 80K kms), ATF (40K and 80K kms) P1818.13
total * 20K AND 60K kms P9775.45 / P11400.45
total * 40K AND 80K kms P12908.58 / P14533.58
total * 100K kms 14155.45 / P15780.45
GEAR OIL CHANGE for manual transmission every 30K kms
Every 40K kms replace: engine coolant, ATF (including transfer, internal and external transmission filter), brake fluid, clutch fluid, power steering fluid)
.. HTH
- 54,198
November 10th, 2018 12:03 AM #1727i'd remove all the flushes and treatments.
i'd fill my wiper fluid myself, and warn them to "keep off my fluids".
...wheel balance...!??
and that heavy check up parts price is highway robbery!
November 10th, 2018 12:45 AM #1728
- May 2016
- 546
November 10th, 2018 01:37 AM #1729
- Aug 2016
- 62
November 10th, 2018 08:18 AM #1730true! It's been a habit of mine to ask for the insurance and maintenance cost of any vehicle I'm intereted in buying and always tell the service staff not to put in "upsell items", just whats required. wheel balance everytime they rotate the tires daw po. anyway, after finding out the mitsu rates (and I cant make my wife change her mind about the Xpander being her "mom mobile"), I think i will be doing my own maintenance kung fluids lang din. I just wish there would be a a consumer protection law here like the Magnuson–Moss Warranty Act - Wikipedia
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
