Page 173 of 209 FirstFirst ... 73123163169170171172173174175176177183 ... LastLast
Results 1,721 to 1,730 of 2090
    #1721
    What's the RPM at 100KPH?
    It's running 1500rpm * 60 kph; 2500 rpm * 100kph
    #1722
    Quote Originally Posted by jvnj View Post
    Surely you passed by the zigzag road of Atimonan Quezon. If you used the "Old" zigzag, then it is a good gauge that traversing the Baguio steep is more bearable.
    Yes, I did pass by the old road going to Bicol. There are certainly some steep segments there but not as lengthy as can be found at Kennon, just before and after the Lion's head. Yun eh kung bukas ang Kennon...
    Though I believe the Xpander can handle that just as easily as it did in Quezon, but I need to test downshifting manually to L2 and L1 to see how she goes. After that, I'll have gotten the car through all the paces I need her to excel in.
    Mar 2018
    #1723
    Quote Originally Posted by Newcomer123 View Post
    This is ok. My friend's Rush is a bit past 3,000 RPM at 100KPH. I think the Xpander has better FC when it comes to highway drives.
    Aug 2017
    #1724
    Kenon is closed to heavy vehicles, only light vehicles are permitted but that is only limited to the residence of the said place. There's a bridge under repair and only alternative bridge to pass thru.few falling rocks on the roads.
    What I do is going down from baguio via Kenon, take some pictures sa lion. Then push thru going down till reach the toll station then stop by security and ask you where to go(if you're residence). Try to please the security to allow you to pass and you need to write your name and plate number sa log book. Took me 20min till reach Rosario junction.
    Note: please be cautious if you want to take the risk.
    Sent from my Pocophone using Tapatalk
    use the brakes..
    Aug 2016
    #1726
    Quote Originally Posted by w123lover View Post
    Anybody have the Preventive Maintenance Sched and expected costs for each?
    eto lang po so far ang info ko, as of current pricing:
    1K / 5K kms
    FREE LABOR
    oil filter P383.00
    gasket 48.00
    sticker radiator cap 8.00
    engine oil 1395 semi-synth / 3020 full synth
    misc 280.00
    fuel treatment 330.00
    total P2444.00 (semi) / P4069.00 (full)
    REGULAR CHECKUP
    10K / 30K / 50K / 70K / 90K kms
    LABOR P3515.44
    wheel balancing 550
    .. everything above PLUS
    engine flush P300
    car care kit 350
    oil treatment 995
    windshield washer fluid 150
    total P8304.44 (semi) / P9929.44 (full)
    LIGHT CHECKUP
    15K / 35K /45K / 55K / 65K / 75K / 85K / 95K kms
    everything above MINUS wheel balancing *P550 and slightly cheaper labor * P3161.24
    P7400.24 (semi) / P9025.24 (full)
    HEAVY CHECKUP
    20K kms/ 40K / 60K / 80K / 100K kms
    everything in REGULAR CHECKUP PLUS slightly higher labor P4374.37, air cleaner P1607.08, spark plugs P4380.00, coolant P1215.00 (40K and 80K kms), ATF (40K and 80K kms) P1818.13
    total * 20K AND 60K kms P9775.45 / P11400.45
    total * 40K AND 80K kms P12908.58 / P14533.58
    total * 100K kms 14155.45 / P15780.45
    GEAR OIL CHANGE for manual transmission every 30K kms
    Every 40K kms replace: engine coolant, ATF (including transfer, internal and external transmission filter), brake fluid, clutch fluid, power steering fluid)
    .. HTH
    #1727
    i'd remove all the flushes and treatments.
    i'd fill my wiper fluid myself, and warn them to "keep off my fluids".
    ...wheel balance...!??
    and that heavy check up parts price is highway robbery!
    Mar 2018
    #1728
    Easiest way is switch off O/D (overdrive).
    May 2016
    #1729
    Quote Originally Posted by RiMsHoT View Post
    1K / 5K kms
    FREE LABOR
    oil filter P383.00
    gasket 48.00
    misc 280.00
    REGULAR CHECKUP
    LABOR P3515.44
    wheel balancing 550
    engine flush P300
    car care kit 350
    oil treatment 995
    LIGHT CHECKUP
    HEAVY CHECKUP
    .. HTH
    Crazy prices for a 1.5L gasoline compact MPV. That's diesel suv territory already. How much will it decrease if you remove all the flushing and unnecessary fluids?
    Aug 2016
    #1730
    true! It's been a habit of mine to ask for the insurance and maintenance cost of any vehicle I'm intereted in buying and always tell the service staff not to put in "upsell items", just whats required. wheel balance everytime they rotate the tires daw po. anyway, after finding out the mitsu rates (and I cant make my wife change her mind about the Xpander being her "mom mobile"), I think i will be doing my own maintenance kung fluids lang din. I just wish there would be a a consumer protection law here like the Magnuson–Moss Warranty Act - Wikipedia
All new Mitsubishi Expander MPV!
