Results 1 to 8 of 8
- Jun 2011
- 2
June 26th, 2011 01:07 PM #1[SIZE="4"]hi guys, i came across a junk 1993 or 1995 itlog lancer and planning to make it my project car. how do i know if it is a 4g15 engine or a 4g92? it doesnt have any papers. what i just know is that it has an sohc EFI engine and no power windows and no power steering. this is where i get confused cos i thought all efi 4g92 engines had power steering but it seems that this one has not... and any suggestions on my project on how i can make this car gain some hp without spending too much money and tweaking of ecu? since i'm from a remote province, there are no shops here that tweaks ecu's.
future plans:
high flow air filter
cold air intake
headers
2"-2 1/2" exhaust pipe
racing cams
polishing of cylinder heads
thanks![/SIZE]
- Jun 2011
- 14
June 29th, 2011 02:12 PM #2I would advise you to focus first on its ride before adding any accesory or customizing some of its parts. Below could be your initial checklist:
Battery
Starter - is it cranking
alternator - is it still cranking after using it.
Lights - as in all lights should be working (from inside to outside)
Oil leaks - check for any oil leaks.
Temperature - is it overheating?
Underchassis - fix all the kalampag major and minor; front to rear
RPM - is it iding well
Each of these has another checklist. just keep me updated. hope this would help you.
June 29th, 2011 02:47 PM #3
no papers? check the papers first if its not a hot car, i believe you cant run around the roads without papers. then for the engine, stock for the gli is 4g15. walang fan belt for power steering? thats odd. i think there is power steering if its gli.
for performance, change to 4g63 is the best for lancer project car but if its just to gain a few hp, intake, headers and exhaust upgrades should do it. cams is also nice and do advance timing hangang magtope na yung tunog. hehe
- Jul 2007
- 18
July 3rd, 2011 01:59 PM #4If it has an engine with EFI and does not have power steering, it is most likely a 93 or 94 GLi with a 4g15 SOHC engine. We have a Lancer 93 GLi without power steering and without power windows. But you still need to check its papers because how can the owner sell it to you without papers.
- Jun 2011
- 2
July 21st, 2011 03:02 PM #5thanks for all your help guys. but i already registered it. it was a 4g15 sohc 1993 model.
any ideas how to make it faster but without spending too much money? i want it to be a "sleeper" (a car that looks slow but in reality, is quite fast) i'd like to be in level with those hatchback civics.
*archie: thought of changing the engine to 4g63 but it would cost me a lot. the engine itself is about 45k without transmission. 60k with transmission
- Jul 2011
- 23
July 27th, 2011 11:20 AM #7
- Sep 2011
- 5
September 14th, 2011 11:57 AM #8
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
