Results 71 to 80 of 178
August 9th, 2021 10:10 AM #71
*as a guy who grey up fixing his own car (ganun ako pinalaki)
yung M/T na Mirage uses a cable for its clutch. Not a big fan.
- Jun 2011
- 1,232
August 9th, 2021 01:34 PM #72Understandable na underpowered ang 1200cc. Letdown nga iyong nag bottom ang suspension. Maganda KYB flex spring ang i install sa start sa factory.
As much as gusto i promote ang local production, mukhang mas okay ang Brio V as commuter.
Kailangan magbaon ng clutch cable kung ganoon.
- Jun 2015
- 2,751
August 9th, 2021 03:52 PM #73I have the CVT hatch. Apart from the trunk space, it's practically the same as the G4.
Cons:
- Sluggish acceleration. It's normally not an issue but when you're in a convoy, medyo effort keeping up with the cars in front.
- Squeaky brakes if you leave it parked overnight after a car wash or rain. Not sure if this also happens in other cars though.
- Non-existent sound proofing lets you hear everything around you. It's like driving with the windows slightly open. Just imagine when it's raining.
- Stock springs are mushy most noticeably at the rear.
- Flimsy body panels. I have a dent on my door from a basketball. I have dimples on my roof from falling fruits.
- Weak AC.
- Steering is vague. Hindi bumabalik sa sentro ang manibela.
- Electric steering tends to overheat if you make too many quick turns while maneuvering in a tight space. Not sure if the same happens to other vehicles with electric steering.
Pros:
- Small turning radius. When others are making K-turns, you can make a U-turn.
- Fuel economy, low emission.
- Magaan ang manibela.
- Kayang umakyat ng Baguio :p
August 9th, 2021 05:20 PM #74
- Nov 2019
- 1,402
August 9th, 2021 07:39 PM #75
- Sep 2016
- 2,348
August 9th, 2021 09:41 PM #76
- Jun 2015
- 2,751
August 10th, 2021 12:57 AM #77You lose power steering. Tumitigas nang sobra ang manibela. There's also a lamp on the gauge cluster that lights up when there's a problem with the steering.
Usually, you'd have to wait a minute or 2 for it to cool down and the warning lamp to turn off.
Happens when you make too many full turns of the steering wheel. Halimbawa pag yung driver hindi pa sanay sa parallel parking. But like I said, I'm not sure if overheating is true for all EPS.
August 10th, 2021 01:04 PM #78
first time ko narinig (nabasa
) itong issue na to.
posted it here (Tsikot) and other forums.
Dec 2017 - Laguna to Subic/Clark (we crossed Metro Manila around 3am)
I rented a Mirage GLS CVT -> we were looking for a small car we can use while we're in Manila, I was considering the Mirage so renting it for a week will be a good test.
5 passengers with luggage. I was also trying to keep up with an Altis and Almera.
F/C for the entire trip... 7km/l, you also feel the terrible suspension when cornering.
- Sep 2016
- 2,348
August 10th, 2021 11:00 PM #79
- Dec 2019
- 2,073
August 28th, 2021 02:48 PM #80Facelifted 2022 Mitsubishi Mirage G4 launched, starts at PHP 769k
-AUTOINDUSTRIYA.COM
Could also be due to the high demand that the manufacturer prioritized new car deliveries vs. spare...
BYD Sealion 6 DM-i
