Results 4,841 to 4,850 of 7539
- Jan 2017
- 275
May 2nd, 2017 09:58 PM #4841
- Jan 2017
- 275
May 2nd, 2017 10:13 PM #4842
I wont dare block my egr ill just install occ foe my gen 3 since euro 4 naman na.
Don’t Block or Remove the EGR Valve, It’s Saving You Money | Tuner University
May 2nd, 2017 11:57 PM #4843
What Is An Oil Catch Can? - YouTube
Sent from my SM-G920F using Tsikot Forums mobile app
May 3rd, 2017 12:03 AM #4844
OCC works as long as you have the patience to maintain it ( cleaning can of accumulated oil, change filter, etc...). For EGR blanking I recall both 4D56 and 4N15 engines do self close their EGRs in instances of stressed situations (engine needs more oxygen) like carrying heavy loads, going uphill and high speed runs. So blanking is only beneficial at lower engine stress conditions.
May 3rd, 2017 12:27 AM #4845
The black substance that blocks our EGRs is soot, one of the bad by-products of diesel combustion. Soot production is directly proportional to the amount of sulfur in our diesel fuel. EURO 4 diesel has 90% less sulfur compared to EURO 2 diesel. Using EURO 4 diesel alone will give you benefits of cleaner exhaust gasses ( less soot meaning cleaner EGR), longer oil drain intervals (cleaner oil) and slightly better engine life. I am one of the early adopters of Unioil EURO 4 diesel back in 2011-2012. My Monty I recall was less than 20,000 kms traveled distance when I started using it. It really does not matter if your Monty is casa or self-maintained as long as you maintain it. Besides EGR cleaning is not a standard procedure which I did not avail in my old Monty's PMS which I only did up to 20,000 kms. After 20k kms regular PMS is done with the help of my suking Shell Station using regular Rimula R4x oil, Vic oil/air/filters. With exception of ATF change (ATF fluid available only sq casa) and timing belt change.
Sent from my SM-G920F using Tsikot Forums mobile appLast edited by roydok; May 3rd, 2017 at 12:36 AM.
- Dec 2016
- 8
May 3rd, 2017 09:00 AM #4846
- Jan 2017
- 275
May 3rd, 2017 12:08 PM #4847Grab the opportunity to check you montero or any mitsubishi unit by Japanese engineer. Check the caravan schedule with the dealer near you.
MMPC Taps Japanese Engineers to Provide Free Inspection in Dealerships - Mitsubishi Motors Philippines Corporation
May schedule.
- Sep 2006
- 143
May 3rd, 2017 12:25 PM #4848
- Sep 2006
- 143
May 3rd, 2017 09:28 PM #4850
Regarding change oil:
5,000kms for mineral oil
10,000kms for synthetic.. how about the oil filter? Is it ok to wait 10,000kms kasi sabay dapat palit ng oil and filter. at sa mineral oil masyadong magastos na every 5,000kms palit oil filter. any thoughts or clarification on this?
One can only hope.
