Page 324 of 754 FirstFirst ... 224274314320321322323324325326327328334374424 ... LastLast
Results 3,231 to 3,240 of 7539
    Sep 2010
    #3231
    Quote Originally Posted by rod13 View Post
    I put a deposit of 10K in Nov 23 and will get my unit on Dec 16. Mitsubishi Caloocan, cash payment will be last in the queue. They prioritize installment according to my SA
    I deposited cash 10k aug 17, sent a copy of manager's check aug. 19, for verification of full payment, got my unit aug 20. Citi motors las pinas is the dealer.
    #3232
    The first thing you ask a dealer when buying a car, cash nonetheless, is if they have your preferred variant and color. And when its available, when can you see it in person.
    If they said 3 week waiting period, and you find it long, then go find a dealer that can get you a unit faster.
    There's a reason why discounted ang montero kasi overstocked sila. Which means mabilis makakuha ng unit.
    This is not like when the 86 was launched na hotcake and supply was low and demand very high that dealers were milking prospective buyers with must get in house financing even if may cash to buy, or must get overpriced insurance and other accessories from dealer just to let you get the unit cash.
    So for them to not prioritize cash buyers? Hahahaha, in short wala silang stock ng exact unit na gusto mo.
    Like me calookan was my first dealer of choice since they are the nearest to have test drive units. But had no units of my preferred color. So i went to the second dealer which had loads of monteros in their top floors, but rejected the unit. On my third dealer they too had lots of monteros and easily released a unit two days after full payment.
    Apr 2004
    #3233
    Until now wala pa akong OR/CR. Nov. 9 pa na-release ang unit so 3 weeks na din. Sabi ng dealer naghihintay lang sila sa LTO. May naka-experience na din ba sa inyo ng delayed OR/CR? Any advice po para mapabilis ang release?
    Thanks!
    Apr 2004
    #3234
    Quote Originally Posted by EsYuBi View Post
    Question po regarding sa steering ng monty. Na exp ko po dun sa isang regular U-turn ko along the way home na hindi kaya ni monty ng isang kabigan lang, kelangan ko pa po mag reverse to pass. Kaya po ito ng isang kabigan lang dati sa Starex 99 Model ko. Thats why medyo nagtaka ako kay Monty hindi po makuha. Medyo maiksi ba talagang ang kaya ni monty sa pag liko compare sa ibang model?
    Best in class na ang Monty pagdating sa turning radius.
    #3235
    Quote Originally Posted by skipper View Post
    Thanks!
    Almost on my second month and i still have no or/cr
    Nov 2007
    #3236
    Quote Originally Posted by LionheartBisdak View Post
    thanks boss kung ganun lang. do u have any idea how to reset it? my wifey lang kasi ang nagmamaneho ni Monty at balak kasi nya dalhin sa casa bukas..your further input is greatly appreciated.
    You can use code 3280 after pressing the triangle icon for 10 secs I think. But it'll give off a warning again after you restart the engine/head unit.
    Reminder Lang yan and nothin to worry about any malfunctioning part
    Sep 2009
    #3237
    In my case my steering vibration when making hard turn and or turns on uphill/downhill. Casa already replaced the steering coupling sa ilalim. Nawala ung issue. However, may lumabas na ibang issue.Pag nadaan sa unven pavement like or lubak like sa edsa, may nararamdaman ako na parang loose or may alog onti ung steering wheel and mas ramdam ko ung feedback sa steering wheel pag nalulubak..worst may feeling na parang kakalas nanung steering wheel pag ung talagang malakas ung at mabilis ung takbo mo..feeling mo kakalas ung steering wheel.
    Quote Originally Posted by hoover View Post
    Thanks bro! So far medyo nag smoothen out na yung vibration sa brake pedal and steering wheel upon braking, baka ganun lang sa umpisa. What i noticed is sluggish lang talaga yung vehicle from 0-30kph, kunwari traffic, and jerky at times. Normal ba to?
    Also, to those with the documented loose steering issues, was it like that when the vehicle was purchased? Or tight in the beginning and then medyo maalog na later on? I understand na hindi "maalog" pag ginalaw mo, and it's more of the feeling while driving. I just forget the term the others used.
    Aug 2004
    #3238
    Quote Originally Posted by morbid29 View Post
    mukha same case tayo ser Morbid. sa akin din napalitan Lower Steering Column shaft, sabi ng Warranty officer same item lang daw except its applied with special grease by MMPC. at first ok sya, then now after about 3months the on -center steering play / loosey feeling is same or worse than before.... this also had been feedback to CASA warranty guy which in turn relays to MMPC. so far no update from them....
    Aug 2004
    #3239
    if u input that "3280" code thru the HU, it will just comeback after u restart the engine. best is if you reset it using Steering wheel mounted Trip meter controls... make sure Engine is not running..... then u are able to set the next PMS reminder to the next set of mileage....
    Aug 2016
    #3240
    [QUOTE=mambo_no_5;2789026]Thank you po sa advice. Kapag repaint ba, the whole. No body po ba gagawin or yong affected portion lng?[/QUO. No no no dont repaint it i rub mo muna ng rubbing compound bka makuha pa
2016 Mitsubishi Montero
