Page 181 of 270 FirstFirst ... 81131171177178179180181182183184185191231 ... LastLast
Results 1,801 to 1,810 of 2693
    Nov 2014
    #1801
    Quote Originally Posted by mervsville View Post
    Try formating USB to FAT32 file format
    Yeah last resort ko sana yan.. kaso iniisip ko, hindi cya makakapag play ng files greater than 4gb. Pero I guess okay lang. better than nothing.
    Before actually doing that, I was trying to find data/spec sheets for the 2014's head unit. So far bigo.
    Thanks for the suggestion!
    Jan 2014
    #1802
    Quote Originally Posted by leinahtan View Post
    * sir bicol_ini, tama si sir monty_GTV ipa adjust mo muna clutch ni teroy. Sa tingin ko hindi TC ang kailangan mo sa uphill traf. Pag sa ganyang situation, laro lang talaga sa clutch and gas. Pag may TC ka, baka sa harapan ka naman mag alanganin.
    Ok po thanks po sa mga responses (leinahtan/monty_gtv)... pa adjust ko na nga muna clutch nasa 5'3" lang po kasi ht ko .
    Oct 2014
    #1803
    Quote Originally Posted by xvanquish View Post
    You will not use 4gb file.. The HU can only play videos with avi format. Even that namimili pa rin. Also HU can only see up to 250 files per folder..
    Nov 2014
    #1804
    thanks sir mervsville for your input. so it seems need ko magdedicate ng flash disk for the monty if ever I wanna play videos on it.. hmmm... thanks again!
    Jul 2013
    #1805
    guys is it okey lang po ba ang 3" straight pipe sa engine natin? or much better kung may muffler?
    kung ang paguusapan po eh performance
    TIA!!
    Apr 2012
    #1806
    Quote Originally Posted by RF02 View Post
    TIA!!
    saan ba kami sasagot sir? lahat ng montero thread pare-pareho ang tanong dito na lang at mukha naman 2014 model yung nasa avatar mo...
    i have no idea sa straight pipe. mine have 2.5" diam all the way with magnaflow muffler. ok naman, performance wise, wala naman significant power gain kung hindi mas maingay kesa stock. others i know have 3" downpipe then 2.5" midpipe, muffler to tail pipe.
    Oct 2014
    #1807
    Correct.. Di uubra sa monty yung pang all around na usb.. Mga videos na gusto ko panuorin, kinonvert ko to avi vga format..
    Jul 2013
    #1808
    thanks sir sa dami ng post ko kayo lang nag reply hahaha
    i think wala pa sigurong naka straight pipe na 4D56 engine....
    Jul 2013
    #1809
    Apr 2012
    #1810
    nalito malamang sila saan sasagot kasi pare-pareho yung tanong sa ibat-ibang thread
    wala pa nga ako nabasa o nalaman nagpa-straight pipe na 4d56 dito sa tsikot o sa mscp. but you can try sir, then balitaan mo kami sa outcome. btw, for muffler selection, you can choose naman either a free flow or reverse flow muffler. yung free flow muffler, parang straight na rin kasi diretso lang yung butas. or if you have the means to buy in the US, you can even try putting a cherry bomb glass pack straight thru muffler. maangas malamang tunog pero performance wise, walang masyadong power gain sa exhaust upgrade.
2014 mitsubishi montero
