Page 680 of 690 FirstFirst ... 580630670676677678679680681682683684 ... LastLast
Results 6,791 to 6,800 of 6900
    Apr 2012
    #6791
    Quote Originally Posted by Olsjam View Post
    Helo mga paps.. Anyone experienced delay after shfting to D (gtv 2012) at reles ung handbrake/footbrake.. Di pa rin mag accelerat..shift back to N then back to D.. saka na cya mg accelerate.. ??
    baka palyado na ang inhibitor switch, have it checked or replace.
    Jun 2018
    #6792
    Thanks for the inputs sir... Planing also to change atf if it will help also..
    Apr 2012
    #6793
    are you near Manila area ba? you can try Zix Performance shop, kabisado nila yang mga aberyang ganyan.
    Jun 2018
    #6794
    Malayo po sir hehe sa Probinsya ng leyte po ako..
    Apr 2012
    #6795
    i see. then safe bet mo ay mitsu casa or find a good mechanic
    Jun 2012
    #6796
    May nakagawa o alam ba kayo guys na naka pagpa kabit ng 3rd/middle headrest sa 2nd row ng monty natin? Tulad ng sa mga gen 3.
    Jun 2018
    #6797
    Dinala ko sa casa.. Sabi replaced whole trany assembly at600k+ daw set.. Juskolord.. Hehe sabi ko ichange oil lng muna at replaced inhibitor switch.. Tapos pinul out ko na.. I tot wala na pagasa.. Yesterday i tried to road test.. At 1st hanggang 3rd gear lng tapos blinking ung D.. Tried to reset tru losen the batery.. Then start road test agen. And use padle shifter.. Suprisingly, umayos na ung tranny.. Tested up to 80kph sped.. So far ok ung andar.. Hopefuly, tuloy tuloy na.. Bukas try ko ulit.
    Apr 2012
    #6798
    kung napalitan nila ng bago yung inhibitor switch, malamang maging ok na yan sir. mostly naman ng mga nagka-issue ng blinking "D" na mga Gen2 ay due to faulty inhibitor switch.
    anong km reading na sasakyan mo sir? bili ka na lang ng bagong modelo kung 600k yung transmission[emoji23]
    Jun 2018
    #6799
    Almost 85k na odo.. Ng makita ko ung estimate na 600k+.. Napatingin talaga ako sa new model montero at sinabihn ko agd ung SA. I DP ko na lng s brand new montero or mirage n lng cash p hehehe
    Munimuni din ako na bumili ng partz out trany.. 10wire pla eto. At nghahanp p ako sa bnawe hehe mostly 9wire ung availble..
    Im.contemplating of changing ATF.. Pero sabi s casa ok p naman daw ung fluid.. 60k last ako ng change ATF..
    Apr 2012
    #6800
    mababa pa yan ah. i highly doubt kung buong tranny assy ang may sira at need palitan[emoji849] you may want to consult sa Zix performance, the owner na ka tsikot seldom post here na but you can check their fb page. they have extensive experience sa montero and he might be able to help you
2012 Montero Sport Owners
