Page 501 of 690 FirstFirst ... 401451491497498499500501502503504505511551601 ... LastLast
Results 5,001 to 5,010 of 6900
    Feb 2013
    #5001
    I found this useful tip...
    The Suction Control Valve (SCV) is responsible for controlling fuel pressure in common rail engines. They move via a solenoid with each small incremental variation of the throttle. The Suction Control Valve uses extremely fine tolerances within their moving parts. These Suction Control Valve is quickly affected by the dirt and or contaminated fuel. When the suction control valve is contaminated or worn they will cause the common rail pump to deliver an inconsistent fuel pressure to what is being demanded by the factory ECU. When the fuel pressure at the injectors jumps around by many thousand of PSI the vehicle driver will experience surging as the ECU tries (and fails) to find the correct operating fuel pressure. This is seen diagnostically when viewed via live data. If the problem of varying pressure moves past a pre set limit of that which the manufacture states should be the normal range for a certain RPM the vehicle will go into limp mode. You can reset the normal operating condition by stopping and re-starting the engine. The problem will re-appear in a short while however. Fitting a Diesel Performance Module (Chip) will always exacerbate the problem. Many people incorrectly blame the Chip for this as the problem may be just under the surface without the Chip fitted. It is at this time that most people head to their dealer for a fix and are given a large bill for the replacement of the Suction Control Valve if it is not covered under warranty. This problem occurs consistently in Mitsubishi Pajero, Triton and Challenger, Nissan Navara, and early and late model Toyota Hilux with the D4D engines. Cleaning and re-installed the Suction Control Valve rotated 90 degrees may fix the problem short term however, sooner or later the Suction Control Valve will need to be replaced. A relearn of the factory ECU will also need to be conducted. - See more at: Standard Suction Control Valve (SCV) Suits Mitsubishi, Nissan and Isuzu - Chip Tuning Australia
    Sep 2013
    #5002
    newbie lang po mga sir, paturo naman kong paano mag egr blanking at kung saan makabili ng plate pang cover egr
    Apr 2010
    #5003
    Quote Originally Posted by zix888 View Post
    well lahat yan binanggit mo are factors sa pagdumi ng scv. regular cleaning and rotating of scv position will help prevent early breakdown. btw just finished cleaning mine, and rotating the position
    Sir Zix,
    Nakakalas pa ba tong SCV mismo or lilinisin na lang ng ganyan pagkatanggal sa engine mount?
    And when you say rotating the position, does it mean pinagpalit lang yong bolt eye pagbabalik or me naiikot na part mismo sa SCV?
    Sorry ha, daming tanong... TIA
    #5004
    Quote Originally Posted by ezrydre View Post
    Sir Zix,
    lilinisin lang bro. and yes, swap lang ng position yung bolt eye.
    Apr 2010
    #5005
    Tnx Sir Zix.
    Sama ko na to sa every 20k or 30k maintenance... hehehe...
    May 2012
    #5006
    Thanks Sir Zix, is worth to buy from casa of this genuine Led Side Mirrors? Almost 19K po kc sya whole set..pos ung luma ko na chrome without led lights eh mababalewala na..
    May 2012
    #5007
    hindi kasya yan sir, wider yan compared sa atin
    #5008
    Quote Originally Posted by sirhcacal View Post
    well i for one didnt go for it, sobra mahal eh. i just made some diy
    arrow led turn lamp on monty - YouTube
    Apr 2013
    #5009
    Sir zixx pa pm naman kung nagkakabit ka ng rear mirror with auto dimming function. Plano ko sanang magkabit. Salamat.
    Sent from my iPad using Tapatalk - now Free
    #5010
    Quote Originally Posted by Bengbeng View Post
    pwede natin paratingin, katulad ba sakin?
2012 Montero Sport Owners
