Page 437 of 500 FirstFirst ... 337387427433434435436437438439440441447487 ... LastLast
Results 4,361 to 4,370 of 5000
    Jun 2013
    #4361
    Quote Originally Posted by D3nb3r View Post
    pag na lift tayo iiba talaga ang geometry nang suspension natin. dapat ingatan natin yung cv joint at yung sa mga naka manual tranny naman delikado din yung center bearing pag nag lift above 2". IMO, pag di ka rin lang naman pumupunta sa mga heavy trailing and ground clearance lang ang habol, then lift block and spacer ay oks na tapos samahan mo pa nang 32" tires so mga more or less 5" na itataas nang ground clearance nun. But if you have deep pocket and budget is not an issue then full aftermarket suspension kit na lang pa install mo
    some info from aussie triton forums:
    Attachment 20901
    Attachment 20902
    Sir kung magpapalift ako ng 3" tapos nakalagay ngyn e 265/50r20, bagay pa ba? Pero gusto ko din upgrade yun tire, anu size na match dun 20" ko with 3" lift.
    Thanks.
    Posted via Tsikot Mobile App
    Mar 2012
    #4362
    Quote Originally Posted by fourstring View Post
    Medyo subjective ata yung "kung anong bagay" na sentence sir. Meaning kung anong bagay tingnan. A rugged look might not be good looking for others but then a low profile look might look baduy to others. Depende po ata yan. The most important is gusto mo yung ginawa mo sa rig mo and alam mo yung feeling na pag baba mo nang sasakyan mo and habang papalayo ka ay napapalingon ka sa rig mo and smile. That means your satisfied with what you did Test fit mo na lang sa shop sir, in that case maka trial and error ka. and also IMO a lifted rig with a low profile set-up would not look good for me, hehehe. but that's just me. We just have to remember not to sacrifice safety for porma dahil most if not all of us here ay hindi naman sumasali sa trails and car shows.
    Sep 2010
    #4363
    Sent from my GT-I9300 using Tapatalk
    Jun 2013
    #4364
    Yan din iniisip ko Sir, I have to change my tire to much bigger. Nun nag-inquire ako sa Jeff's Offroad ng 295/55R20 na Nitto suggest nga nila atleast 3" lift para walang rubbing.
    Ok na siguro yun ganon.
    Mar 2012
    #4365
    check mo yung rig ni sir guilf https://www.facebook.com/guilf.nadunop/photos_albums naka 285/50/20 yan, -12offset nang rim. angas nang porma nyan. Plan ko similar din na set up sa kanya but ipon muna for the lift, rim and tires, bago lang kasi ako nag pa install nang HID projector.
    Jan 2011
    #4366
    makisabad na nga po...
    pag ang ipapalit ko pong tires ay 270/70/17, kailangan pa ba ng lift?
    Jun 2013
    #4367
    San ka Sir nag palagay ng projector? Ok ba yun nabibili sa sulit?
    Jun 2013
    #4368
    Mar 2012
    #4369
    sa https://www.facebook.com/redlineautoworks ako nagpa install and as of now sila yung authorized retrofitter nang TRS(The Retrofit Source Inc) dito sa pinas. i'm not sure nang mga binibenta sa sulit but nag popost din sina Angelo Magtoto (redline autoworks) and Gary Quizon (HIDretrofit.com) dyan, yang dalawa name lang ang alam kong magaganda yung mga set-up and mga original yung mga parts. Pinadala ko sa Manila yung headlight ko for the retrofit since i'm from mindanao.
    #4370
    Can i ask if turbocharged dn ba ang 2008 strda gl? Tnx
2010 Mitsubishi Strada [continued 2]
