Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Oct 2011
    anyone of you had a problem with their montero about check engine suddenly lit up? I brought my montero to the casa and the S.A. told me there was a problem with the fuel i used that it was dirty and with water and that is why they had to change the fuel filter. I wonder if it was really true or the casa people would just make alibi's to earn a profit. This happened twice already and i was using a petron turbo diesel so how come that diesel was dirty? What was more peculiar was when i was about to bring the montero to the casa, the check engine light just disappeared. I was thinking it was the sensor or the computer that has a problem....
    Any suggestions? thanks.
    Jul 2004
    so far i have not encountered this problem
    i am using seaoil bioxceed
    but will monitor though
    Feb 2011
    iba ba sir yung seaoil bioxceed sa seaoil biodiesel?
    madaming monty owners gumagamit ng seaoil diesel ah. so maganda talaga ang result sir? :D
    Aug 2013
    Dear Everyone,
    i think the fuelling station/dealer is not the issue. I also have the same problem, it happens 5 times already and i also change the refuelling station but then it recurs. Everytime i bring my unit to the casa there's no clear explanation what is the root cause of this problem. I believe there's already a quality issue on these montero cars esp on 2013 model that must be addressed immediately. I am so frustrated. The freebies that i should have asked were paracetamols to relieve me from the headaches it brought me along with this new car. On tuesday aug 27, 2013, I will bring my unit again to the casa to be check. I dont know what to do anymore, I am thinking to return the unit totally since this is still under waranty. I just bought this last April 2013. Please help. Your opinions or suggestions will be highly appreciated.
    Feb 2013
    If my check engine light sasakyan mo and nag on ito, automatic stored yan sa memory ng sasakyan unless otherwise i-clear ng scanner ito. A tkahit pa i-clear ito ng scanner lalabas ulit ang error after sometime dahil di naman ni-resolve yung issue.
    Kung diesel fuel ang issue, magsasabay ang check engine light at ang fuel filter light mo, kasi nga madumi therefore enough yan para magtrigger yung sa fuel filter mo.
    Kapag di natrigger ang fuel filter mo ng problema, or hindi na sense at nagkaroon ng check engine light, malaki ang probability na sa fuel pump or injector part mo ang issue.
    Pinakamaganda nyan is have your car scanned then kunin nyo yung error codes. Kung sinabihan kayo wala error code pero angcheck engine light, ginogoyo lang kayo ng casa.
    same thing with our pajero bk.. 10k pa lang natatakbo nag check engine na.. yun din ang problema sa fuel, pinalitan ng fuel filter then binaba at drinain yung fuel tank.. and meron din parang filter sa tank na nilinis nila.. so far mag 20k na hindi na ulit nag check engine.. btw, since then sa seaoil na din nagpapalagay ng diesel, buti na lang bago bukas seaoil dito sa amin before kasi sa petron..
    Nov 2011
    Quote Originally Posted by mbs View Post
    Dear Everyone,
    buy or borrow a OBD 2 scanner and read the check engine code your self, there we will see who is telling the truth!
    Jul 2004
    Quote Originally Posted by ericson21 View Post
    Pareho lang ata yung dalawa kasi alam ko, isa lang ang klaseng diesel ng Seaoil
    Quote Originally Posted by lightsnow725 View Post
    Try to fuel-up in a different gas station but Petron TD din gamitin mo. Baka marumi yung fuel nung dati mong gas station. It could be another thing to see. Also, get a second opiion also outside the casa.
    Just don't go to Rapide, palit injectors at buong fuel system yan. joke
    Aug 2004
    It's possible it can be a fuel problem. I've experienced similar in other cars when I filled up diesel at a cruddy gas station.
    If you always fill at the same station, go to a different station.
2011-2012 montero gtv check engine sign problem
