Results 1 to 10 of 10
- Jul 2004
- 24
August 9th, 2004 11:33 AM #1Mga tol,
Though parang walang solution, still I am hoping na someone can give me a bright idea so this problem.
I have no garage so I park on the road. Almost monthly, my tire cap is being stolen. Buti na lang at di everyday.Is there a way para di manakaw ang tire cap?
August 9th, 2004 11:40 AM #2
Unfortunately wala unless you glue it shut or remove it everytime you park at night.
What kind of caps do you use? Rubber or yung bakal?
- Jul 2004
- 24
August 9th, 2004 11:49 AM #3Vinj,
Tol ty. Yung parang stainless. I do not know kung rubber or bakal yon. Usually pa naman, yung dalawa lang ang nananakaw. Yung kalapit sa gutter hindi. But last night, naging tatlo na. Natira lang ay yung isang nasa front tire. Seguro dahil di na naabot.
August 9th, 2004 12:07 PM #4
You could buy some 'locking' cable ties (used to organize cables like inside appliances), and tie them to the wheel itself. You need to cut them nga lang if you want to remove the cap, but it sure makes stealing the cap a hell of a lot harder.
August 9th, 2004 12:24 PM #5
i use the stainless caps before pero nawawala lang when i park my ride. ngayon balik plastic ako yung 15 pesos each hehehehehehehe.......... yung natirang stainless sa spare tire ko na lang inilagay.
August 9th, 2004 12:39 PM #6
palit ka na lang ng plastic less hassle yun. Pero dati dun sa may mendiola nagpalit na na ako black plastic tire caps ninanakaw pa rin. mga taong walang magawa. !*!#!$!!^%#!
August 9th, 2004 03:28 PM #7
Pwede mo din palagyan ng Etching ng Plate Number. Hanapin mo na lang ung thread na un dito.. Side Mirror Etching ang title.
August 9th, 2004 05:23 PM #8
takaw nakaw talaga yung mga tire valve caps. kaya bayaan mo na lang na wala.
August 9th, 2004 06:55 PM #9
Tighten it with pliers, a quarter turn will do. Then use pliers again when you need to put air in.
Kahit na plastic or stainless, even alimunum caps can be tightened with extra torque.
Tsikot Member Rank 3
- Mar 2003
- 637
August 9th, 2004 10:49 PM #10what are we talking about here yung takip ng pito o hubcaps? kung hubcaps yung sa amin hindi ninakaw pero binasag naman siguro nahirapan makuha kaya sinira na lang.
oo nga, sa link ni LOLZ it's $226, your info is $216, not far nga from casa's quote of P12k So I...
ABS and Handbrake Lights Both On
