Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
    Oct 2011
    Stop Using Canola Oil Immediately
    It’s my hope that you’ll never use Canola Oil again! Why? Because of GMO’s (more on this below) and the harmful side effects from the processing of this oil. You know that Olive Oil comes from olives, and that Sesame Seed Oil comes from sesame seeds. It would make sense that Canola Oil comes from Canola Seeds, right? Well, there’s actually no such thing.
    Canola is a made-up word which stands for “Canadian oil low acid”, and is a genetically modified product. It is a Canadian invention that is backed by the government. It’s a cheap product to manufacture, and almost all processed or packaged foods contain canola oil.
    Facts You Should Know About Canola Oil
    Canola Oil is produced from the rapeseed plant, which is a part of the mustard family. It’s an industrial oil, not a food, and has been used in candles, soaps, lipsticks, lubricants, inks and biofuels. Rapeseed oil is what is used to make mustard gas. In its natural state, it causes respiratory distress, constipation, emphysema, anemia, irritability and blindness.
    Now that we have figured out how to genetically modify rapeseed oil, we sell it as an edible product. It has been brought to market with the claim that it is a wonder oil, that is low in saturated fats, and has omega-3 fatty acids. The problem is that it is still just rapeseed that has been genetically modified.
    Studies have shown that rapeseed has a cumulative effect, and can take close to ten years to manifest symptoms. One claim of long term use is the destruction of the protective coating around the nerves called the myelin sheath. This is how Multiple Sclerosis begins. Some of the symptoms presented have been:
    Shaking & Tremors
    Breathing Problems
    Difficulty Walking Or Writing
    Slurred Speech
    Heart Problems
    Thought Process Degrades
    Memory Problems
    Low Audio Levels
    Urinary Incontinence
    Nervous Breakdown
    Numbness Of Extremities
    What else can it do to you? Canola oil will deplete Vitamin E, and will interfere with normal metabolism and enzyme function. It also suppresses the immune system. Rapeseed Oil is a monounsaturated oil, and has high levels of erucic acid. Erucic Acid is a fatty acid that is associated with heart damage, specifically Heshan’s Disease, a disease that manifests itself with fibrotic lesions of the heart.
    In the 1970′s, food manufacturers came up with a method to genetically modify the rapeseed plant by seed splitting. This process produced a canola oil with less erucic acid, and higher amounts of oleic acid, which lead to additional concerns with canola oil, like:
    Blood Platelet Abnormalities
    Retards Normal Growth (Illegal in infant formulas)
    Free Radical Damage
    Higher Cancer Risks Due To The Hydrogenation Process
    It’s also important to understand that this new processed oil goes through many steps, most of which harm the nutritional value, introduce toxins, and actually change the oil’s structure causing it to become hydrogenated oil.
    Those are the types of oils you want to avoid like the plague: Hydrogenated and Partially Hydrogenated oils!
    Trans fatty acids are the result of this hydrogenation process. These are hazardous by-products, and are health destroyers. You should stop cooking with these oils:
    * Corn Oils * Safflower Oils * Soy Oils
    Food manufacturers are not required by law to tell you if their products contain GMO’s. It’s up to us to be well informed, and read the labels. Monsanto has been incorporating genetically modified organisms in its canola oil seeds, and now we know that Monsanto has also been selling GMO seeds for the following plants:
    Canola
    Alfalfa
    Corn
    Cotton
    Wheat
    Sorghum
    Soybeans
    Sugarbeets
    How to Choose A Good Oil
    When you’re buying a cooking oil, consider these things:
    1. Choose a “Cold Pressed” or “Extra Virgin” type.
    2. Should be available in glass containers.
    3. The bottle should be a dark color, and kept in a dark place once opened.
    4. Make sure it is GMO-free.
    5. Go with Organic.
    What does Extra-Virgin Mean? It’s simply another way of referring to “cold pressed”, which means that the oil was made by using pressure to extract the oil from the seeds, grains, nuts, etc., and there was no heat utilized during the processing. Heat causes a degrading of the nutritional value of the oil. Extra Virgin also means that no chemical solvent was used, nor was it deodorized or altered in any way.
    What Oil to Use Instead? I personally cook with coconut oil more than any other oil. It’s good for weight loss, cooking, moisturizing and tons of other great uses. I recommend the brand Garden of Life Coconut Oil, which you can get at my online store, HERE.
    Now that you’re armed with the facts, use them to guard your health! Stay clear of Canola Oil, and all GMO foods.
    Source: Stop Using Canola Oil Immediately » DrAxe.com
    I've read this several years ago. I'm not sure if it's true. We don't use Canola Oil naman talaga but my Lola used to and I told her to just got with Coconut Oil or Olive Oil. The problem with Olive Oil lang is you can't use it on high heat.
    no canola oil.
    mahal eh.......
    hanggang minola lang kami.
    Yeh yeh yeh
    My my my Whew!
    Ma ma ma My Minola!...
    We use Canola Oil before. Now coconut oil nalang, yung natipid pang istarbaks at jeyco.
    Signature
    Aug 2003
    We used to use it a lot, then bigla na lang bumalik sa coconut oil. The fad sorta wore out i suppose.
    Slightly OT, but since we're discussing health concerns:
    i also see olive pomace oil being sold in supermarkets, way cheaper than olive oil...but i read on wikipedia that it has potential carcinogens.
    Olive pomace oil - Wikipedia, the free encyclopedia
    Oct 2011
    lauric oil na rin gamit namin ngayon.
    I would still go for pure olive oil.
    Meron din na Mediterranean Oil, it's way cheaper than Olive oil, it's a mixture of Canola, Olive & Grape Seed Oils.
    Aug 2010
    Who would have thought Retz was actually into cooking.
    Anyway,
    Right.. 10 years to manifest symptoms. Lahat naman dangerous sa mundo eh: walking down the street! changing a lightbulb! hell, even coffee is labeled as a carcinogenic substance.
    P.S. Olive oil and Canola still rules our oil family.
    Feb 2012
    I bought a liter of Canola oil once, and never again. Balik Baguio/Minola oil na lang. I bought one before even researching about it. Nadala lang ng ad copy sa label. Just got concerned with the smell when I first used it on high heat. Parang amoy sunog na motor oil yata if I remember right. Basta something na you would be bothered instead of smelling edible na gaganahan ka sa amoy.
