ok cge po try ko ito maya..
saka iisaisahin ko nakasulat dito sa thread na to...
waging war with the garapatas!!!
salamat!
Quote Originally Posted by ooba99 View Post
You can use asuntol as spray. Ilagay mo lang sa atomizer (spray bottle) yung asuntol solution and spray small amounts to the pups' ears. Be careful not to flood the ear as it may cause naman ear infection if the solution gets deep into the ear canal.
The spray solution you can use for preventing recurrence of infection by spraying unto the walls, corners, and crevices on the areas where your dogss usually are.
HTH.
