Results 1 to 10 of 29
- Aug 2003
- 9,720
May 5th, 2013 07:13 PM #1The roof seems to be springing a lot of leaks lately...considering that the past few rainshowers this year haven't been that intense, i'm a bit concerned that it might get worse during the wet season.
From what i gather from past repairs, the GI sheets seem to be OK, nagkakaproblem lang sa mga dugtong/nailpoints.
Ano kayang magandang solution:
1. Vulca seal
-- imho, a bit hard to pinpoint where to apply it; sa tag ulan lang talaga magiging obvious
2. rubberized roofing
-- i'm hoping that coating the entire roof would be aone shot deal, to seal up the leaks and also provide heat insulation.
-- mahal ba to? how much per sqm lalabas?
-- any special procedure to apply it, or do we just buy a few cans and paint it on?
tia
May 5th, 2013 07:26 PM #2
If leaks were not a problem w your roof before, Clean the gutters, spouts and drains tapos vulcaseal muna. Check well the edges and flat sheets that may need repair or replacement. Vc
Sa akin, design defect talaga yung isang part ng house so perennially may leak problem.
I doubt the rubberized will help much though. Mas okay pa rin insulation.
Check also for water seepage from the walls and gutters.Last edited by vinj; May 5th, 2013 at 07:38 PM.
- Aug 2003
- 9,720
May 5th, 2013 07:46 PM #3
- Oct 2009
- 2,271
May 5th, 2013 07:52 PM #4ako ginamitan ko ng cord marine epoxy tibay!!!
sa akin honda singlaki ng piso ang butas nakana pa ni cordmarine epoxy
sa unang apply parang hindi kakapit at malabnaw..pero kapag natuyo...potek sing tigas talaga ng bato sing tibay ng isang sakong semento ..
2years na dipa naman bumibigay..
May 5th, 2013 08:55 PM #5
That's a very expensive problem
OT: May thread dati dito on asphalt shingles. Maganda siya pero maganda din presyo. hehehe.
May 5th, 2013 09:31 PM #7
- Jan 2011
- 445
May 5th, 2013 10:33 PM #9
on the shee metal joints try evo-stick flashband. this is like a tar like band of sticky tape. available in most hardware stores. medyo ma kamahalan lang. it comes in various lenghts and widths. for all its worth, get a guy that you can pay on a per day basis and have him slather vulca seal on every nail or bolt head that he sees, plus the roof edges.
May 5th, 2013 10:54 PM #10
I found a comprehensive Oil Analysis of different SK ZIC oils from Russia. Translate it yourself. ...
Zic engine oil
