Results 161 to 170 of 902
- Mar 2010
- 2
March 2nd, 2010 12:41 PM #162
What genset capacity should I get to power the following:
2 2.5hp split type A/C
1 1.5hp split type A/C
2 1.5hp window type A/C
1 1.0hp split type A/C
3 TV sets
3 refs
2 units hot/cold water dispenser
1 3200W water heater
at least 40pcs 18W CFLs
March 2nd, 2010 01:36 PM #163
March 2nd, 2010 01:53 PM #164
masyado malaki yong 60kva for that particular load.
base on my computation (maximizing those without no given wattage), its only 30kva.
hope this help.
March 2nd, 2010 02:17 PM #165
even if the load is 30KVA, you don't buy a 30KVA generator
you buy least 40KVA
but i think 40KVA is still too small for that load
better to have headroom than overload a smaller generator
it's very expensive to repair a generator that burned out due to overload
March 2nd, 2010 03:24 PM #166
How much would a 40KVA and a 60KVA genset cost? Meron ba yung hindi maingay? I'm going to place the genset beside the quarters of our workers para may bantay.
March 2nd, 2010 05:29 PM #168
how can an overload happens when the total connected load is given and i based my computaion on that? plus there is what we call usage factor. what i'm giving is 95 percent efficiency usage. that means you are not throwing money for unused energy produced by your generator. am i right or wrong?
March 2nd, 2010 05:33 PM #169
if you throw in 40kva, the efficiency will become 70 percent. throw in 60 and the efficiency will become 50 percent. can you see now the wasted money?
- Sep 2008
- 736
It's about 1 cm longer than the 3SM and about 4 cm longer than the DIN74. And it's also in the 10k...
