Results 1 to 7 of 7
- Apr 2003
- 526
May 29th, 2006 12:10 PM #1what are the pros and cons sa paggamit ng foam vs coil spring beds?
generally don't have backpains naman pero don't want to start developing backpains din dahil sa bed.
eto yung website ng uratex regarding their foam beds, may blue and yellow(ortho) foams din sila.
http://www.uratex.com.ph/html/foam/f_cnsprod.htm
tia
- 10,620
May 29th, 2006 12:27 PM #2pinaka ok is the pink foam....
foam ang gamit ko kasi ayoko ng nalulunod ako sa bed
May 29th, 2006 12:44 PM #3
ang alam ko lang...mas malaming yung coil spring beds, kasi mas may space yung hangin sa ilalim ng kama, saka bunot yata yung palaman ng coil spring beds. foam beds, mainit higaan pag mainit ang panahon. pag wala kang kobre-kama na maganda, pagpapawisan ka (except kung naka aircon ka). saka last but not least, mas maingay ang coil spring bed pag..eherm...alam mo na ;)
May 29th, 2006 01:02 PM #4
coil spring beds can easily get destroyed.... my kids are expert on this. Once sira na yung springs, hindi na straight yung surface nung bed, and minsan lumalabas yung dulo ng spring sa surface. tiniis namin na ganito yung bed namin for a few years, until i had frequent stiff neck problems. nung nagpa x-ray ako, my spinal cord curved a few degrees. i had to undergo 2 weeks of PT and was advised to change my bed to foam... kahit di daw ortho type as long as solid yung pinagpapatungan ng mattress.
- Apr 2003
- 526
May 29th, 2006 01:54 PM #5pink foam yung comfort plus?
yah, am trying to avoid problem with the coils na nasisira. tsaka ang ok daw sa foam type is hindi nagshashake yung buong bed pag may isang malikot.
May 29th, 2006 02:18 PM #6
IMHO, foam is better and also cheaper. If it gets worn out, you can just have it replaced without burning a hole in your wallet.
May 29th, 2006 03:25 PM #7
Regarding init, I don't agree na mas mainit ang foam, we have both sa same room, parehas lang ang init provided na may sheet sa ibabaw.
Will wonders never cease with Motolite? Ha ha.
