Results 71 to 80 of 101
September 17th, 2020 11:32 PM #71
After a week with the Xiaomi 3H, very happy so far with my purchase. Initially I thought I cheaped out by buying a Xiaomi instead of Sharp, but the Xiaomi is much more feature-packed.
There are also far more reviews on the Xiaomi 3H than the Sharp FP-J40E that it goes head to head against, and all the reviews have been positive:
https://en.smartme.pl/xiaomi-air-pur...epca-recenzja/
Mi Air Purifier 3 review: The all-rounder of air purifiers - Technology News
Xiaomi Mi Air Purifier 3H, review: Xiaomi’s most advanced air purifier is controlled from mobile | Euro X live
Xiaomi Mi Air Purifier 3 Review: There Are Absolutely No Arguments Against it
I couldn't even find a single review of the Sharp FP-J40E. But I did check it out in person in Abensons - it's larger, yet has a lower CADR (clean air delivery rate). Plus it doesn't have any screen so it doesn't give you the PM 2.5 levels, temperature, or humidity like the Xiaomi does. Neither is it smart enough to connect to Mi Home or Google Assistant. All while costing more (11k Sharp vs 6.5k Xiaomi).
The Sharp G40E purifier that has humidity, light, and temperature sensors costs 18k, almost 3x what I spent for the Xiaomi, and it still doesn't have wifi connectivity.
Even vs older Xiaomi purifiers, the 3H is a big upgrade. Higher CADR, better filtration, and less noise than the 2S that it replaces, while only being 500 pesos more expensive.
Definitely a recommended buy.
September 18th, 2020 12:34 AM #72
Sharp ph's marketting slept on the competition. They have excellent air cleaners in japan.
- Oct 2012
- 4,851
September 22nd, 2020 12:45 AM #75
Looks like I need another air purifier for my bedroom. While the Xiaomi works well for the living room and dining area, at night I don't have purified air in the bedroom since the door is closed and the aircon is running.
Unfortunately Xiaomi doesn't have a tabletop purifier. My top options are either the Nobico Air Purifier (2k) or the Carrier tabletop air purifier (6.7k).
I know Carrier is Carrier but I'll be spending the same amount I spent on my Xiaomi air purifier for a smaller/weaker purifier so parang hindi sulit. Then it doesn't look like they have supply of the replacement filter pa.
The Nobico naman is an unheard-of brand but it has hundreds of good reviews on Lazada and even a few on YouTube. Filters are also readily available and super cheap (380 per replacement filter).
I'm inclined to get the Nobico, unless anyone has other suggestions for a small tabletop purifier that works for a small bedroom.
September 22nd, 2020 04:15 AM #76
do you open the windows? my parents open the living room glass doors and their bedroom windows. fortunately its not too dusty near the 3th floor.
September 22nd, 2020 08:45 AM #77
Jut, what made you choose the 3H over the 3C? It has the same coverage for almost half the price, though the 3H has more filters ata. We're you able to check if the filters are readily available and acceptable cost? Thanks
September 22nd, 2020 10:34 AM #78
I want this air purifier too, but mostly because of this:
Upgrade Xiaomi Air Purifier to Leafless Fan more quieter fit for xiaomi purifier 1 Pro 2 2S 2H 2C 3 3H | Lazada PH
Dysonesque bladeless fan attachment.
September 22nd, 2020 11:49 AM #79
Yes, I open my living room sliding door in the afternoon to let fresh air in.
Got my 3H for 6.5k because of a flash sale. 3C today is 6.9k. Spec-wise, 3H has higher CADR also (380 vs 320 m3/h).
HEPA filter for Xiaomi 3/3C/3H is about 1.5k, replaced approx every 6 months.
Hina niyan bro. Since the fan operates on low/auto mode most of the time, hina din ng air volume. If you put it on high naman, maingay.
But pansin ko now because of the circulation of the purifier, I don't need my electric fan as much. Might also be that the weather now is cooler than summer.
- Oct 2012
- 4,851
September 22nd, 2020 01:46 PM #80
Mahilig kasi sa profit ang ford. Strategy yan na huwag gawing matibay ang mga parts para maraming...
BYD Sealion 6 DM-i
