Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
    Ano effect pag hindi balance ang gulong?
    Maingay? Maalog?
    Maalog steering.
    nanginginig sa manibela pagmabilis na takbo. usually around 80kph above
    Sent from Constantinople
    maingay? may effect din ba kahit sa likod ang hindi balance?
    Kung maingay, baka sa goma na.
    Fwd, OK lang hindi balance likod pero kung naging maalog, pacheck na rin.
    You might get a wiggle especially around 40-60 kph.
    May maingay kasi sa likod... pacheck ko nga kung goma or bearing na.
    naka 17 40s kasi ako at nankang ang gulong.
    Jan 2009
    The vehicle speed at which the oscillation starts happening is not the same for all vehicles. It depends on the amount of imbalance, the dimensions of the tire and how tolerant is your steering mechanism. Some have reported 60kph while some only starts to feel it at 140kph.
    Feb 2012
    Wow! Same problem I was about to ask here.
    Currently I am also experiencing road noise apparently coming from my rear end. Not sure din kung tire o wheel noise ba yun or kung sa bearing na ba. It started lang kasi since I changed to Yokohama A-Drive yata (confirm ko mamaya). It started barely noticeable. Akala ko dati me tricycle na nakasunod sa akin. Now it's getting worse, even as slow as around 40kph nag-start na umingay. Nagtataka lang ako kasi parang wala naman ako narinig na ingay sa harap samantalang same tire din lang naman. Only difference di ko pa ulit napa-balance gulong ko sa likod. When I bought my wheel and tires kasi kasama na wheel balancing. Pero when I got to SLEX grabe ang alog ng manibela from 80kph pa lang. So pinare-balance ko at naging swabe na. Sa likod same worse balance pa rin. I am thinking to change my rear tires to another brand or another model, pero baka kasi di pa rin ma-resolve. Sayang kasi relatively bagong-bago pa mga tires ko.
    Dec 2009
    Guys ask ko lang. Pag nag tire rotation ba kailangan pang i wheel balancing?
    Posted via Tsikot Mobile App
wheel balancing...
