Page 127 of 241 FirstFirst ... 2777117123124125126127128129130131137177227 ... LastLast
Results 1,261 to 1,270 of 2403
    Apr 2008
    #1261
    Yep. Happened to be in convoy with my brother who was using my other car so I got the dashcam video from there.
    A few thousands difference is still worth it IMO. Achilles for my size is around 3.5k, while Advan V701 is 5.5k. So that's roughly 8k difference for a set. If the tires last 2 years, then I spent 4k per year for better tires and peace of mind. To each his own of course - after all it's your money, your car, your safety.
    Good thing you did not hit the wall when you slid and spun. That was a close save there. In what condition were your tires at the time?
    Agree about the safety aspect. Though I sometimes justify the cheaper purchases like the Westlakes with the reason that the car is pretty much only used in city driving. My father is Taiwanese, grew up with Nankang tires, and swears by their quality. Both the Granvia and Santa Fe now use Nankangs. The Carnival gets Bridgestones though. Lucky bloke. [emoji23]
    Sent from my SM-G900I using Tapatalk
    Feb 2005
    #1262
    Just purchased 4 new tires for one of our sedan. Got Forceum brand for 2.2k each, Thailand made, if I am not mistaken. Medyo na distract kasi ako kanina
    Got it from a tire shop along P. Tuazon in Cubao.
    First time to try this brand, let's see how it will perform.
    Sent via AsusZ3M
    #1263
    Sent via AsusZ3M
    Mura naman...anong size?
    Feb 2005
    #1264
    185 65 14.
    Sent via AsusZ3M
    #1265
    Quote Originally Posted by GTi View Post
    Around 2.5-3mm remaining tread. Still above the 1.6mm threshold. Actually I was able to run with the same set of tires for almost another year until I sold the car.
    So it wasn't really worn past useability. It's typical for cheap tires to drastically suffer in terms of grip as they wear out.
    #1266
    185 65 14.
    Sent via AsusZ3M
    Mahal pala dahil maliit lang. [emoji3]
    Aug 2014
    #1267
    hi guys,
    nag inquire ako ng tyre, replacement (AT) yung nirecommend nung tindahan is achilles tyre 235/70R15 - 4200 ang price, ok lang ba price nito?
    and yung sa existing ko naman is 225/70R15, ok lang yun merong konting difference sa witdh?
    tia.
    Quote Originally Posted by aioshin View Post
    hi guys,
    tia.
    find the right size. wide tires affects/increases fuel consumption.
    shops will sell you anything...
    also why AT tires? HT will be quieter, better braking and better fc..
    Apr 2008
    #1269
    ^Agree. Unless you require the added traction afforded by AT tires, HT tires will suffice. They are usually cheaper and quieter too.
    IMHO upsizing this much will not cause significant effect to fuel consumption. If original tire size is not available, I don't mind upsizing as long as both sides are of the same size.
    Aug 2014
    #1270
    Yes, for additional traction lang, I'll just try to find a correct size tomorrow. Yes, some store, they will just sell as long as they can, and if you ask if ok lang ba yun, ok lang ng ok.
Low budget yet good quality tires
