Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Feb 2012
    sir ung nkalagay sa sticker 185/65r14 30front 29 rear.sa stock mags.pero ung mags ko 15" tire 185/65r15.ano po tamang psi.civic 96 po ride ko..salamat
    Feb 2012
    Mine is at 195/60/r15 from the stock 185/70/r14. after testing different psi's for both tires, from 35 down to 30... I've decided and settled on 30psi all around. From 32 to 35, talagang matigas pa. Tolerable naman sana, pero I'm worried mostly about my under carriage parts. Even dashboard and doors are making noises pag nalulubak. sa 30psi, swabe lang,,, compromise between ride comfort and fuel economy. After running for a while, mag-settle din sya to about 33-34psi.
    Stock wheels ng FD ko ganyan yung size - 185/55/R15
    30 ako all around. Kapag out of town or malayuang byahe, 31 all around.
    Jan 2004
    likewise 30psi for my r14 tires
    Jun 2010
    take note dapat cold tire ka dapat mag check ng pressure para sure, 30 psi sakto
    Feb 2012
    yup. i forgot to specifically mention that, though i did state that after running for a while it goes to 33-34psi due to heating and expansion. i mostly do my readings very early in the morning, and bought a digital tire gauge specifically for that.
    available at handyman and i guess true value for P495. for about the same price, meron din sa concorde ibang brands naman.
    Feb 2012
    guys than you po,i go for 30 all around.
    Jul 2004
    it depends.
    kung mainit yung panahon, 30PSI is the most ideal tire pressure pero kung tag ulan, we highly recommend 32PSI.
    ***falken tires usually 35-38PSI
    Feb 2012
    Quote Originally Posted by NdoymaN View Post
    it depends.
    sir falken tire di ba brand po yan,,michellin po ung sa akin,,30psi din po ba un
    Jul 2004
    Quote Originally Posted by redfoxmavson29 View Post
    Yes Sir. 30 PSI po recommended for other brands lalo na sa ganitong kainit yung panahon..
    And please nitrogen po ilagay nyo ng tumagal buhay ng gulong nyo.
Confused of proper psi for 185/65r15
