Results 1 to 10 of 14
- Apr 2009
- 272
April 13th, 2015 03:21 AM #1I have a corolla 97 which uses the 185 65 r14 tire. Currently im using good year assurance. So far ok naman siya been using goodyear for so many years already. Im planning to change tire na sana, should i continue to use goodyear? or dunlop and bridgestone are better? meron din kasi promo yung bridgestone na 3+1 kaya medyo tempting :D
- Nov 2009
- 38
April 13th, 2015 10:56 AM #3the 3 plus one ng bridgestone is a bit misleading.
They will offer you a 3 plus one promo based on SRP price ng gulong.
There are dealers who are already offering a max cash buy discount of 25% less on srp. This is essentially the same as the 3 plus one promo. so parang marketing lang yung 3 plus 1.
Been using potenzas (Re001 and Re002) on my innova. best grip on wet, compared to dunlop lm703. grip is comparable to michellin ps3. These are based on daily drive only.
Ive never used goodyear pa due to horror stories ive read here.
April 13th, 2015 11:25 AM #4
bridgestones din ako.
ayoko ng goodyear, maingay....
dunlop had that reputation na manipis/malutong ang sidewalls.
also consider Gajah Tunggal.....
Yokos are also ok.
Yokos are also ok.
April 13th, 2015 11:58 AM #5
Never had issues with bridgestones. Wala akong masabi sa quality. Mauubos mo talaga yun tread nang tire. Sulit!
- Aug 2014
- 66
April 13th, 2015 02:50 PM #7
We should really start comparing each tire size/brand/tread pattern independently. There's a broad range of quality in each brand. Although it's true that some brands are worse across the whole lineup.
AFAIK for 185/65r14 Ecopia EP200 is the only tread pattern available for Bridgestone. The equivalent for Yokohama is Blue Earth AE01. Both are fuel saving tires. Yokohama also has a regular non-fuel saving tire "C Drive". No experience using either but a friend who has a shop says these tires don't have many returns/complaints.
Forgot the tread pattern of Goodyear and Dunlop for that size but I would stay away from them due to the number of complaints from separations from Goodyear and weak sidewalls from Dunlop.
- Jan 2015
- 468
April 13th, 2015 03:30 PM #8toyo tires.
been a fan of goodyear since my time and memorial. pero nagtry ako yoko okay naman (pricey lang siya for a daily use car), pero i found a new pal my Toyo Proxes. hihihi
ganda ng grip, and still checking if it will last long enough like my good year< yoko.
mura kasi sa cavite ang Toyo Proxes 2.8k lang.
toyo tires.
April 13th, 2015 05:41 PM #9
- Nov 2009
- 38
April 14th, 2015 12:25 PM #10https://facebook.com/notes/945690892130222/
Eto po ung list kung saan available ung promo
Gaano na katagal na Brand ang Yokohama battery? and Megaforce?
