Results 1 to 4 of 4
    Need assistance from the SME's if the mags from the CRV will fit the HRV and where to source it. Interested in upgrading the shoes.
    Thank you in advance and Happy New Year!
    Quote Originally Posted by wsa 400 View Post
    Either the CASA or wherever 2nd hand market shop you know.
    As to if they will fit... they will, but most likely, you'll need to switch to a different set tires on the HRV. Mataba yung gulong ng CRV, and the wheel itself is slightly wider (7" vs 7.5").
    The rims will fit as both the CRV and HRV use a 5x114 bolt pattern.
    However, the stock tires of the CRV are 11% bigger than that of the HRV so you'll have to change to lower profile (thinner) tires if you want to use the CRV's rims on your HRV to maintain roughly the same tire circumference as stock.
    Quote Originally Posted by mda View Post
    Thank you for the reply and tips. Will look at the tire shops in Banawe and Evangelista.
2017 18" oem Honda CRV mags on 2017 Honda HRV
