Results 1,961 to 1,970 of 1970
- Apr 2017
- 31
June 22nd, 2018 08:13 AM #1961Nu na po balita sa 3rd row seat? May nakapagpalagay na ba?
Sent from my LG-H870DS using Tapatalk
- Apr 2017
- 31
June 22nd, 2018 12:17 PM #1962
- Mar 2015
- 11
June 30th, 2018 09:40 AM #1963Good pm, newbie here, would like to ask if any have experienced with fob key not being detected, display shows key not detected. Change fob battery to no avail, used spare still with same result. Started with door handle button not working, driver and passenger, presently I use the center console key slot to get engine started. I drive a 2010 model. Any response appreciated. Brought my car to Kia Pampanga and initial diagnostic run through their computer didn’t show any error. Ask service advisor if they encounter the problem and he has no answer so decided not to leave vehicle. Remote functions work fine door lock and the red led lights up with a press of the button. On occasion, this error will be overcome if I press push start button repeatedly, around 3 to 4x.
Change main battery, but still the same. Key not detected.
Any suggestion appreciated or service center. Thank you.
- Apr 2017
- 31
August 18th, 2018 03:58 PM #1964Mga sir, ano po magandang gulong sa sorento natin?
- May 2006
- 1,668
- 54,192
August 19th, 2018 01:12 AM #1966
August 19th, 2018 01:13 AM #1967
- Apr 2017
- 31
August 21st, 2018 11:11 PM #1968Stock po. 235 65r17. Pinagiisipan ko kasi nexen nfera ru1-5600 each. Kumho kl21-6700. Yoko g055 6700. Baka may marecommend po kayo iba pa. Thanks
- Oct 2006
- 6,244
August 22nd, 2018 05:51 AM #1969I recently got a set of Nexen N8000 (P6k each) from Mindanao Tyre Haus. Ok naman so far. Tread pattern is not SUVish, but lets be realistic, who brings ours off anyway? I don't.
Tsikot Member Rank 3
- Aug 2004
- 2,452
September 15th, 2018 09:43 PM #1970nagawa ko na 'yan before, just back read na lang. anyway i went with the OEM route. mas mahal sya kasi need to change interior (side) trim. puede naman sa Seatmate para mas mura...
u can check here also
<https://www.facebook.com/search/str/SORENTO+CLUB+PHILIPPINES+3rd+row/keywords_search?filters_rp_group=%7B%22name%22%3A% 22my_groups_posts%22%2C%22args%22%3A%22%22%7D>Last edited by parakitoJDM; September 15th, 2018 at 09:47 PM.
Not just the engine. It's literally a D-Max with Mazda styling, but everything mechanical is Isuzu....
2022 Mazda BT-50 (3rd Gen)
