Results 1 to 6 of 6
June 14th, 2012 01:30 AM #1
Mga Sir,
Ganito po nangyari, yung drain plug po ng makita ay mayleak, ayun sa brother ko, pinapalit na yung drain plug pero nagkulang yung oil (econo oil ang gamit ng trooper from casa), ayun sa mekaniko ok naman daw yung castrol oil na pandagdag kaya ayun dinagdagan, bale less than a half liter po naidagdag,, tanong ko po, may effect po ba ito sa fuel injectors or sa buong makina in the long used, thanks po mga Sir.
- Sep 2006
- 89
June 14th, 2012 03:58 PM #2IMO walang epekto yan as long as yung Castrol engine oil is either multigrade, semi or full synthetic with a viscosity of 5W-30 or 10W-30.
June 14th, 2012 05:18 PM #3
June 17th, 2012 12:11 PM #4
- Nov 2010
- 236
June 18th, 2012 01:12 PM #5sir kung half liter or less lang nadagdag no problem naman po....be sure next time just use the besco oil im also not a fan of isuzu econo oil for trooper i used it once dipa umabot ng 5000km nagbawas ng langis trooper ko(dun sa mark sa dipstick ay naghalf nalang siya) but sa besco never nagbabawas ng langis...
pag wrong grade of oil ang nagamit possible masira ORPS(oil rail pressure sensor) and/or injectors...
if you want sir buy kanalang ng besco oil and filter sa jayson sa oil 600 pesos ang diffference pag sa casa and sa filter naman nasa 950 lang sa jayson dalawa na yon sa casa isa 900pesos and the small one is around 500pesos
June 18th, 2012 06:38 PM #6
Di ko alam about sa miata. But I was able to help my uncle acquire a unit para sa pinsan ko kasi...
6th Gen Mazda MX-5 Miata
