Results 1,971 to 1,980 of 3710
- 227
March 6th, 2012 07:14 PM #1971I had that experience before also dun sa XUV ko. Ilang balik na ako sa Servites sa Timog but everytime, their machine says camber/caster/alignment and balance is normal and yet kitang kita na hindi pantay yung ubos nang gulong. Since I live in Cainta, I decided to bring it to Servitek Marcos Highway and yun, huli! Its been 2 years already and ok pa din naman yung alignment.
March 6th, 2012 11:04 PM #1972
ano ba gamit mo na gulong? yong stock ba na Goodyear forterra ba yun??...if yes, hindi nga pantay ng pudpud ng gulong na yan. Kahit na aligned naman ang sasakyan mo hindi pantay ang pudpud nyan. Aside from that, maugong pa yang gulong na yan. Palitan mo ng gulong, yan ang remedyo dyan. nag palit ako ng Michelin, ayun my problem solved.
- Mar 2011
- 13
March 7th, 2012 10:33 PM #1973Hi Guys, my question is ilang liters po ba langis itong model na Ito Crosswind XTO 2001 M/T non-turbo. Also san maganda mag palinis ng aircon na affordable. TIA.
- Apr 2009
- 551
March 8th, 2012 12:12 PM #1974japogi 4 liters ang xto same year tayo. ako last time nagpalinis sa cool attack sa may julia vargas corner meralco ave. near metrowalk. parang 2k ginastos ko 2yrs ago.. ilan fuel consumption mo? and anong gamit mong tires?
thanks
- Apr 2009
- 551
March 8th, 2012 12:24 PM #1975rkitxt matanong ko lang anong brand ng 205x65 na pinalitan mo and anong brand ng 205x70 na pinalit mo? how much?
yung xto ko naka 205x70 balak ko namang palitan ng orig specs na 205x65.
thanks
- 227
March 9th, 2012 09:17 AM #1976Hello Choco_Mallows, you can try this:
1. With the engine off, step hard on your brake pedal, hold it for a second or two and then release. Repeat this for 3 to four times.
2. After doing step #1, step on the brake pedal again (applying some pressure but not too hard) and start the engine. You will feel the pedal going down. Do not release the pedal yet and hold for a few seconds. This means the brake booster is working.
3. Release the brake pedal.
Hope this helps. Let us know if it worked.
- Feb 2012
- 7
March 10th, 2012 02:45 AM #1977
March 10th, 2012 04:43 PM #1978
Just want to share my sportivo 2005 shock absorber replacement, I replaced with 4 pcs. KYB Gas Excel made in thailand and I was very satisfied sa naging results. No more nose diving when sudden braking, feeling firm ang sasakyan, no more bounciness on irregular road. di na sya kumakabig kapag biglang nahipan ng malakas na hangin.
- Feb 2008
- 10
March 10th, 2012 08:08 PM #1979
- Feb 2012
- 7
March 11th, 2012 01:14 AM #1980Ask ko lang, na experience nyo na ba pag gabi hirap humatak crosswind nyo? yung sa akin kasi pag open na ng headlight parang di agad pumapasok ang shift, pero sa umaga ok naman, so ginawa ko sinubukan ko na buksan headlights sa umaga ayun delay talaga pagpasok ng gear kailangan itodo apak sa gas tapos dun pa lang magsi shift ng gear , so suspect ko pag binubuksan headlight ganun ang nangyayari. Ano kayang diprensya? sa alternator? anyone na naka experience nito? XTO matic pala yung sa akin
Ilang taon at km run na yang casa stock battery na motolite mo ?
