Results 1 to 10 of 42
- Feb 2011
- 53
March 23rd, 2011 04:44 PM #1hi sirs
gusto ko po malaman kung saan pwede makakuha ng gantong engine
saka tranny nito
pang engine swap po sana sa 12t engine ng owner type jeep
or pwede pa po kayo mag suggest ng good turbo diesel engines thanks !
March 24th, 2011 01:42 AM #2
March 24th, 2011 07:07 AM #3
- Feb 2011
- 53
March 24th, 2011 12:28 PM #4
- Feb 2011
- 53
March 24th, 2011 12:31 PM #5
- Feb 2011
- 53
March 24th, 2011 02:25 PM #6inde po ba kaya ng hydraulic brake ang 4jg2t ??
kasi kaya naman po ng brake ng owner namin 4person *
130km/hr
March 24th, 2011 03:05 PM #7
If I may butt in gentlemen,
Bukod sa brake upgrade kung ganung kalaki at kabigat na diesel engine e pati front suspension...sa gaan ng owner jeeps sa likod at bigat sa harap baka ma-oversteer that can lead to a spin.
Consider mo na rin ang roll-over protection system (ROPS) kahit fabricated lang sa 2 inch steel tubing at safety seatbelts kung ganyang 130 km/h ang tinatakbo mo.
Usual sizes ng brakes for pickups (>1 ton Net Vehicle Weight) are 7/8 in for the master cylinder while the wheel cylinder is larger (say 15/16) with a booster of course.
just my suggestions sirs.
- Feb 2011
- 53
March 24th, 2011 04:31 PM #8
Copy that
BTW may Roll cage na po saka seatbelts yung owner namin pinang lolong distance kasi namin minsan at sa NLEX/SCTEX po namin dinadaan hehe kaya kelangan talaga ng Seatbelt saka kelangan talaga ng matinding preno pag oovertake sa national road eh hehe kaya nag invest narin kami duun
although malakas naman ang 12t ng toyota gusto ko parin mag turbo diesel eh para mas matipid pero walang ganung bawas sa performance niya kaya gusto ko rin ng medyo malaki laking turbo diesel engineLast edited by jctapit13; March 24th, 2011 at 05:03 PM.
- Feb 2011
- 53
March 24th, 2011 05:04 PM #10
Ito ba hanap mo sir?
- Four cylinder inline, water cooled, overhead valve diesel engine with dry liners available in Turbo(T) or normally aspirated(NA).
4JG2 TD
Bore 95.4mm
Stroke 107
Displacement 3.059 litre
Compression ratio 20:1
Idling speed NA 750, T 720 rpm
Firing order 1-3-4-2
Injection timing NA: 1 deg after top dead centre(ATDC), at top dead centre(TDC) for turbo
Valve clearance (cold): 0.4mm for intake and exhaust
- Producing 114 PS (84 kW; 112 hp) at 3,600 rpm, and 260 N·m (192 lb·ft) at 2000 rpmFasten your seatbelt! Or else...Driven To Thrill!
How much room do you have between the battery terminals and the hood seeing the the 3SM is much...
