Results 7,611 to 7,620 of 7661
Tsikot Member Rank 3
- Aug 2004
- 2,452
April 1st, 2019 04:24 PM #7611Guys sa mga naka Gen3. Got tons of available upgrade options. Just go thru my FB page "https://www.facebook.com/TunerAutoImportsPhil/".
Sent from my vivo 1804 using Tapatalk
April 10th, 2019 02:02 AM #7612
Hi Sir! Long time!
Vin had the same problem before e. Parehas kayo naka Theta. Parang nasa fuel pump ata ang issue niyan. Pero dapat hindi na mag start ulit. Try ko itanong kay Vin kung paano naayos yung sa kanya.
Yun sa akin kasi na-dalawahan na ako hehehe nasisira yung socket ng fuel pump tapos ititirik ka talaga.
- Aug 2012
- 138
May 3rd, 2019 05:34 PM #7613Hi guys, need to replace my 2013 tucson 4x2 brake pads... Whats the best option na di maingay? Thanks!!!
Sent from my VTR-L29 using Tapatalk
May 4th, 2019 06:50 PM #7614
Questions on tucson crdi 2010-2014:
1. Are any of these eps already?
2. How is the 4x4? For light offroad conditions only, loose gravel and 3-4 inches of sticky mud?
3. What is the fuel consumption in city driving?
4. Any notable problems - suspension, engine, body?
I still have not decided on which coding car to buy kasi. I was choosing before between vitara 4x4 2009-2016 (non available in the market) and forester 2.0. 2009-2012.
I'm presently eyeing a 2014 crdi model with 38k on the odo.
Thanks.
- May 2019
- 12
May 15th, 2019 06:45 PM #7615I also bought a 2.0 CVVT Tucson https://www.xeoto.com.vn/hyundai/tucson and I'm quite satisfied with its performance. I also like its sound system as it already has an aux input that allows me to put in my IPOD.
May 23rd, 2019 03:01 AM #7616
1. I have the 2015 crdi and its eps.
2. I got stuck once in sticky mud, the type of mud you will find in fishponds, tucson is light so its easy to push. The low ground clearance and the HT tires are also not helpful in sticky mud.
3 8 km/l in metro tmanila traffic.
4. Kalampag sa rear, I omce loaded 4 sacks of rice at the back, I replaced all the rear bushings, the noise is still there.
4a. Turbo hose, if not properly set after PMS , part of the hose will touch the header and slowly burn a hole in the hose.
4b. The front under cover is made of plastic, its easily damage if you hit an object on the road. Cost 3.5k to replace, but the part is hard to find.
Its a good cuv, drove it twice to sagada and banawe with no issues. I also drove it to cebu and back via bicol.
- May 2019
- 1
May 23rd, 2019 05:12 AM #7617Hi Guys,
I'm planning to buy a 2nd hand "2012 Hyundai Tucson CRDI" Sa mga nakikita ko dito sa forums parang ang daming nagkakaron ng issue? Sulit parin ba sya bilihin or would you recommend something else?
Some reasons kaya gusto ko ung Tucson sana is because of the Looks, Ground Clearance, Diesel
Meron din ako nabasa na nagkaron ng Mass Recall for 2011 to 2014 Tucson. Are those for Gas versions or kasama mga Diesel?
June 14th, 2019 06:44 PM #7618
- Aug 2012
- 138
June 14th, 2019 07:26 PM #7619
June 14th, 2019 07:31 PM #7620
Agree with you there. Nicely put.
2022 Mazda BT-50 (3rd Gen)
