Results 1 to 10 of 17
- Jun 2011
- 9
June 28th, 2011 08:26 PM #1Hi, I'm a new member here, would like to ask what type of headlight bulb is installed on Hyundai Santa Fe 2011? 2 low bulb and 2 high bulb? if i decide to change it, any advice what halogen bulb brand to buy? does it require a wire enhancer? thanks.
June 29th, 2011 06:27 AM #2
Iba ba yan sa previous SF.. H4 ata.. (I cannot recall hehehe).. Anyway, why do you need to change the halogen bulb? May problema na? You don't need to install a wire enhancer if you just follow the right wattage...
BTW, welcome to tsikot and I hope you can also register in our local Santa Fe group.. Hyundai Santa Fe Club of the Philippines
Mas madami kang matatanungan dun from simple accessories to additional mods..
June 29th, 2011 06:29 AM #3
June 29th, 2011 09:02 AM #4
H7 for low beam then H1 for high beam. Same bulbs for the 2006-2009 SF.
H27 (881 / 880) naman sa fogs.
- Jul 2009
- 2,618
June 29th, 2011 09:14 AM #5sa H7 i've gotten good results with Phillips x-treme. same wattage as stock sya but with more light output. so plug and play sya no need to upgrade your wires/sockets.
- Jun 2011
- 9
June 29th, 2011 11:09 AM #6[QUOTE=imperialv;1778084]Iba ba yan sa previous SF.. H4 ata.. (I cannot recall hehehe).. Anyway, why do you need to change the halogen bulb? May problema na? You don't need to install a wire enhancer if you just follow the right wattage...
Mas madami kang matatanungan dun from simple accessories to additional mods..[/Q
No problem sir, just want to upgrade my lights. Hid sana, but then i have read that you need to have retrofit for the hid para nice yung result ng lights mo.
- Jun 2011
- 9
June 29th, 2011 11:42 AM #7
- Jul 2009
- 2,618
June 29th, 2011 07:54 PM #8approx. 1.5 years na. so far ok naman sya. plug and play sya dahil 55watts lang din naman same as stock. did not change wires fuses and/or housing. medyo mahal lang ng konti got it from blade 2.2k or 2.5k ata cannot remember exactly how much pero you can buy them cheaper for certain in places like banawe.
- Jun 2011
- 9
June 30th, 2011 10:02 AM #9
- Jun 2011
- 9
June 30th, 2011 10:08 AM #10
I feel the same way. Not a fan.
2022 Mazda BT-50 (3rd Gen)
