Results 1,661 to 1,668 of 1668
- Jun 2010
- 466
May 21st, 2014 01:15 AM #1661
- Jun 2010
- 466
May 22nd, 2014 09:51 AM #1662
- 508
May 22nd, 2014 01:24 PM #1663Did they change the whole compressor or just the wheel with the bearing? Usually pag pinalitan yung bearing ng compressor wheel when it is not properly mounted then it can emit noise or the bearing is stil the culprit. Pwede rin kasi na yung tension ng belt. The casa should know that. Otherwise it might be something else.
- Jun 2010
- 466
May 22nd, 2014 03:57 PM #1664
- Oct 2012
- 142
November 15th, 2014 02:05 AM #1665I bought a pre-owned 2013 Theta II Premium last October. It had only 1,400 kms. on the odometer and luckily just a few scratches. However it was left outside by the previous owner for a long time (8 months) w/c left lot of watermarks and scaling so I had to spend 3 days detailing it myself. I washed and clayed it twice then polished it thoroughly. I'm thinking maybe a coat of Wolfgang Deep Gloss Sealant or Optimim Opticoat permanent paint coating as soon as I have the scratches retouched. Will try to upload pics when i get the chance. Hope to upgrade the stock speakers to something that can improve SQ. I don't need expensive gears, just better than stock.
June 22nd, 2015 06:01 AM #1666
First time ko magpa change oil outside the casa since out of warranty na yung unit. Used around 4.2 liters lang talaga ang Sonata 2.4?
- Apr 2011
- 12
October 4th, 2018 11:55 AM #1667How are your Sonatas doing? Any major problems? Recalls? Looking at a pre owned one
November 30th, 2020 08:26 PM #1668
Due for replacement na ang aircon compressor ng Sonata. Nag babawas ng freon and na leak test na lahat ng pwede ma leak test na parts. How much kaya compressor?
It's about 1 cm longer than the 3SM and about 4 cm longer than the DIN74. And it's also in the 10k...
