Page 306 of 319 FirstFirst ... 206256296302303304305306307308309310316 ... LastLast
Results 3,051 to 3,060 of 3189
    #3051
    doubledouble.
    Quote Originally Posted by Horsepower View Post
    That's why it's best to read up and study about specifications before purchasing.
    Personally, I stay away from belt driven timing mechanism engines. When it snaps (and it will), the engine is almost always done as the engine will destroy itself. You get downtime and hassle because the manufacturer chose to cut corners (in guise of giving you a more silent engine).
    Best is gear driven, then silent chain, then belt but try to stick with the first two whenever possible.
    Hopefully your friend's engine will be covered by hyundai warranty (and we're all familiar how horrific claiming warranty from Hyundai is).
    Most cars use timing chains now. Toyota and Hyundai use timing chains In all their vehicles. Im guessing the belt being talked about is the drive belt. Maybe some pulley was wobbling or the tensioner was loose.
    If its the timing chain, there was a timing chain tensioner that needed replacement in hyundai forums for one elantra.
    Oct 2008
    #3053
    Quote Originally Posted by eon red View Post
    total damaged, naputol talaga siya kase hindi na umandar. his car was towed
    Sir can you confirm if it was the drive belt not the timing belt? bec i thought hyundai use timing chain; correct me if im wrong. my elantra's engine is the 1.6l also im about to reach 60k km.
    Oct 2008
    #3054
    also can someone direct me to the link of the tensioner issue mentioned above.
    thanks!
    Jan 2010
    #3055
    hi guys im planning to buy a second hand 2013 Elantra CCVT GL1.6L AT, mileage is at 54k. any thoughts on this, your advise is greatly appreciated. Tia
    Quote Originally Posted by kishAn View Post
    thorough inspection lng. check brake pads medyo pricey original pads. last atf change, normally this is done 45k/60k, last engine oil change. fuel filter change is 45k/60k.
    if suspect of flooding, you can remove the rear seats with a socket, two bolts, i think its a 17/19 or 21mm check. also remove the spare tire. check the bottom part.
    engine sound after cold start, this is one of the several topics in hyundai-forums...
    aside from that, my hyundai mechanic didn't mention anything else about the car.
    Jan 2010
    #3057
    thanks SE. by the way, i also need a hyundai Elantra expert mechanic near bicutan area to inspect the unit. hope you guys can help me with this
    Jun 2008
    #3058
    my friend's 2013 elantra broke down a week ago due to a busted timing belt
    that fast, huh?
    sino po may same experience sa friend ko?
    err ang alam ko 1.6L gamma & 1.8L nu ang makina with timing chain ang elantra. correct me if i am wrong mga ka tsikot.
    Mar 2011
    #3059
    tanung ko lang kung may contact number kayo ng tindahan sa banawe
    im looking for a tail ligth 1pc sa elantra
    TIA
    Mar 2011
    #3060
    double post...........
2011 Hyundai Elantra [MERGED]
