Page 648 of 808 FirstFirst ... 548598638644645646647648649650651652658698748 ... LastLast
Results 6,471 to 6,480 of 8077
    #6471
    Quote Originally Posted by JJB View Post
    Thanks GS guys =)
    hindi ko lang mahanap yung release ng shift lock. Saan banda yung butas dapat? sa ibang cars kasi nasa tabi lang ng knob but sa GS hindi ko talaga makita. You might have a pic where it is located
    Para ngang wala a....
    I'll go down and check it bro... I drove it to the office (after a long while) this time e.....
    BTW, ours is TCI AT.
    Update: Just checked it,- I could not find one on the center column underneath the front panel where the AT stick is mounted.
    Q: Are the brake lights turning on when you step on the brake pedal? Reason I am asking this is that in our then Honda car,- if the brake lights would not turn on,- you can't shift from Park, and you have to use the shift lock slot (by inserting the key) to get it out from Park. What complicates this is that the brake lights and the horn are on the same fuse,- so if you changed to a more powerful horn,- then it could blow up the fuse and inhibit you from shifting from Park.... BTT: If the brake lights are not turning on,- check the brake lights fuse. Good luck bro.
    I'll get back to you on this,- I will review the operations manual tonight.
    28.5K _/_/_/_/_/:starwars:_/_/_/_/_/
    #6472
    may lock sa park. probably loose contact on brake switch or loose wiring at the solenoid. open mo na lang muna yung maliit na cover then sundot ng very small screw driver to shift from p.
    I cannot find this "small cover", too.... Bro.yebo must be correct..
    Wait,- there is one in the center column near the accelerator... Did not pry it open.... You may want to try it...
    Check it na lang bro.,- good luck.....
    #6473
    Nothing mentioned in the owner's manual, bro.....
    Sent from my Nexus 7 using Tapatalk
    Oct 2015
    #6474
    Can anyone recommend a shop that can fix a leaking rear window? Give up na ako sa Hancars. Parang pulitiko kausap mo, titingnan ko ng titignan ko ang sinasabi pero ang final destination ng usapan rejected claim pa din. Any reco would be appreciated.
    BTW for anyone still considering Hancars beware. Warranty is only for engine and tranny. I'm a rant away from betting my left nut they'd deny warranty on that as well. Shame on you Hancars.
    Nov 2007
    #6475
    Quote Originally Posted by Wh1stl3r2 View Post
    Leaking lang sir yung Rear Window nyo? wala mga maliliit na kalawang sa lower side ng glass sa rear window?
    #6476
    yan isang dahilan bakit sa 3 hyundai ko di ako bumili sa hancars. maganda unit pero pag may problema iiyak ka. hari, love-hate relationship pero they honor the warranty. gagatasan ka lang nga sa PMS pero ganun din naman independent dealers.
    Jul 2006
    #6477
    Buti na lang hindi ko binili sa Hancars yung GS ko.
    #6478
    L
    Leaking rear window? Yung sa gilid ba o rear windshield?
    Apr 2012
    #6479
    Pati FB page ng Hancars niraratrat na din dahil sa warranty claims
    #6480
    Try Aguila Glass.
2008 Hyundai Starex (Gen. 4)
