Page 549 of 808 FirstFirst ... 449499539545546547548549550551552553559599649 ... LastLast
Results 5,481 to 5,490 of 8077
    Apr 2012
    #5481
    Quote Originally Posted by Manxter View Post
    Hancars offer 3 brands of oil for PMS: Castrol Semi, Zic Semi, and Hyundai Mobis DPF Premium Synthetic Oil. Surprisingly, most clients choose Castrol Semi. At Hancars, you have a choice.
    Under our local driving condition, it is not true that fully synthetic oil change should have 10,000 kms interval. That will kill your engine dead prematurely. You can do that with gasoline engine maybe, but never with diesel engines. You may do that in Europe, but not in the Philippines. At any rate, experts agree that if you want to use Fully Synthetic oil on a diesel engine, you must change the oil filter every 5K, and top off.
    Since our Hyundai Fully Synthetic oil is less than P2000 higher than our semis (for 6.5 liters), customers choose to have oil change.
    Those are CF rated oils. Manual says that CH-4 engine oils are minimum requirements for CRDI VGT engines.
    What kind of Zic are you using?
    The ATF used on the GS are the fully synthetic ATF, SP-4. The GS Automatic Transmission is designed to work on fully synthetic ATF only.
    And yes, it is advisable to always turn on your rear A/C even at its lowest fan speed, and low cool. This will prolong the life of your A/C.
    If anyone of you sirs have technical questions, you may email me at: hancars*hotmail.com
    Thanks for your support, and pls give my kind regards to numbah5.
    Is ATF SP-4 equivalent to DEXRON IV?
    How many litres ba capacity ng ATF ng Grand Starex?
    Apr 2012
    #5482
    One of our neighbors' GS's front and rear lights were modified/augmented for/with LED lamps....
    WTF!- Nagmukhang perya ang itsura, sa laki ng ilaw ng sasakyan.... I'll take pictures if I have the chance,- kakatawa....
    “Familiarity breeds awe”
    23.5K:fart1:
    Mukha na bang Carousel bro? Haha
    #5483
    Good catch bro. A lot of shops and casas push the Fully Synthetic/Semi Synthetic piece more than the API rating, which is on the user manual.
    Apr 2012
    #5484
    What I don't like is they dont allow their customer to bring their own oil, which is way better than their FS/SS Oils.
    Especially that Castrol, very bad experience with that, magaspang ang andar, ramdam na ramdam ko nung nag ZIC UP ako, ang layo talaga
    #5485
    Been good with the Delo 400. And just recently the Delvac MX. Mineral oils, but some say they're semi-synthetic. No biggie, coz they're CI-4 and they'll be dumped after 5,000 kms anyway.
    Oct 2004
    #5486
    Is the Castrol you're using the magnatec? Sobrang pangit nga ng oil na yan pero no choice ako since yun pinipilit ni pitstop. What I do is I just buy it outside para mas mura.
    Posted via Tsikot Mobile App
    Apr 2008
    #5487
    Good day! Just had my stock tire replaced with also same brand hankook RA08 for Php5900 at banawe. The only thing different that i noticed was the original oem hankook is made in korea, but the new pair that i bought is made in CHINA. I hope it does not affect the quality of the tire.
    Apr 2012
    #5488
    Mukhang Kumho ipapalit ko na tires. Or goodyear but 225/70
    #5489
    Quote Originally Posted by dandang View Post
    If I remember correctly, parang made in China din naman yung stock Hankook na nakakabit sa GS. I'm also due for tire replacement, baka Kumho ang kunin ko bad experience kasi ako with either Hankook or Nexen.
    #5490
    San sa banawe, which store?
2008 Hyundai Starex (Gen. 4)
