Results 5,471 to 5,480 of 8077
June 16th, 2014 01:25 AM #5471
Plus it helps heaps with the circulation. Hindi laspag ang harap kasi sagot nung likod yung pagpapalamig nung, well, likod...
No Signature
June 16th, 2014 09:53 PM #5472
- Sep 2008
- 7
June 17th, 2014 06:18 AM #5473The 110 KPH speed limiter is a new law in Korea for vehicles with capacity of more than 9 persons. All Hancars Grand Starex have been reprogrammed back to no speed limiter. We can reprogram your GS if they have speed limiter and you want it removed. The 160 KPH instrument cluster is deterrent to drivers who are speed demons, but you can watch your speed go all the way to 220KPH on our HUD. And we can also replace your cluster to 220 KPH.
- Sep 2008
- 7
June 17th, 2014 06:28 AM #5474The Euro 5 engine has a trouble free EGR. If some of you are experiencing low power on Euro 5, it may be caused by other factors other than the EGR. Having regular PMS will be good for your GS. Guesswork or tsamba may not work on your GS, as it has a digitally managed system. A dedicated scanner is needed to talk to its system.
June 17th, 2014 06:42 AM #5475
- Sep 2008
- 7
June 17th, 2014 06:46 AM #5476Hancars offer 3 brands of oil for PMS: Castrol Semi, Zic Semi, and Hyundai Mobis DPF Premium Synthetic Oil. Surprisingly, most clients choose Castrol Semi. At Hancars, you have a choice.
Under our local driving condition, it is not true that fully synthetic oil change should have 10,000 kms interval. That will kill your engine dead prematurely. You can do that with gasoline engine maybe, but never with diesel engines. You may do that in Europe, but not in the Philippines. At any rate, experts agree that if you want to use Fully Synthetic oil on a diesel engine, you must change the oil filter every 5K, and top off.
Since our Hyundai Fully Synthetic oil is less than P2000 higher than our semis (for 6.5 liters), customers choose to have oil change.
- Sep 2008
- 7
June 17th, 2014 06:56 AM #5477The ATF used on the GS are the fully synthetic ATF, SP-4. The GS Automatic Transmission is designed to work on fully synthetic ATF only.
And yes, it is advisable to always turn on your rear A/C even at its lowest fan speed, and low cool. This will prolong the life of your A/C.
If anyone of you sirs have technical questions, you may email me at: hancars*hotmail.com
Thanks for your support, and pls give my kind regards to numbah5.
- Sep 2008
- 7
June 17th, 2014 07:03 AM #5478
June 17th, 2014 08:25 AM #5479
One of our neighbors' GS's front and rear lights were modified/augmented for/with LED lamps....
WTF!- Nagmukhang perya ang itsura, sa laki ng ilaw ng sasakyan.... I'll take pictures if I have the chance,- kakatawa....
“Familiarity breeds awe”
23.5K:fart1:
Otoh, the 2nd gen mu-x slightly looks like a mazda up front and some interior bits as well but oto...
2022 Mazda BT-50 (3rd Gen)
