Results 821 to 830 of 14856
November 18th, 2008 07:59 PM #821
November 18th, 2008 09:55 PM #822
- May 2006
- 316
November 18th, 2008 10:06 PM #823
- Sep 2008
- 13
November 19th, 2008 02:30 PM #824
- Nov 2008
- 115
November 19th, 2008 06:00 PM #826
save like ants
ngayon may new car ka na, try mo to save little by little para by 5yrs time nakaipon ka na ulit para you could buy a brand new vehicle in cash.
i opened the air filter assembly last night
air filter 1k+ km. city driving metro manila
mas ok kaya yung knn air filter replacement. pag due for replacement na yung stock air filter parang i want to try knn.
- Apr 2003
- 526
November 19th, 2008 09:18 PM #827how exactly do you drive with the paddle shifters? same ba to sa tiptronic na semi-manual mode?
as in anytime pwd ka magdownshift and upshift even if ur not in the correct speed/rpm range? is it smart enough to detect in case ur downshifting by mistake?
November 20th, 2008 12:41 AM #828
November 20th, 2008 02:37 AM #829
by switching to S mode, you have more control of the paddle shifters. though you can still do the paddles in D mode.
the paddle shift system is wise enough to detect if you are going to blow up the engine or make the engine work hard. in a specific speed, you can only upshift/downshift only in a range best suited for the engine. so let's say you are cruising at 60kmh and you are 5th gear on manual (paddle shifters in S mode), then you tried to downshift to 4th... engine will rev up high dito and when you immediately try to go down to 3rd gear, the system will not allow you to since you are going to blow up the engine anyway. this may not be the accurate way to illustrate it but this is close enough para makita how wise the system works. just the same, if you are going around 30kmh and on 3rd, you have to reach certain RPMs(around 1500+ ata) for the system to allow you to shift to 4th. and also if you are travelling at 60kmh on 5th and for some reason you forgot to press on the accelerator and downshift, the system will automatically downshift for you...
(Gurus, correct me if I'm wrong)
November 20th, 2008 04:25 AM #830
Agree with you there. Nicely put.
2022 Mazda BT-50 (3rd Gen)
