Results 1 to 10 of 12
- Sep 2009
- 15
January 8th, 2010 09:11 PM #1Mga Paps help naman pls. 2 days ago, naramdaman ko pumapalya ung oto ko pag naka segunda or tersera na ako. Hanggang napapansin ko, palala ng palala. Ngayon kahit nasa primera ako o kahit ano gear palyado pa rin. Kanina pumunta ako sa shell service center, 1.pinalitan nla fuel filter ko. 2. Pinalitan nla distributor oil seal and oil ring kasi tumatagas daw ung langis ko. (which i dont know kung may kinalaman un sa prob). Pagtapos nla gawin, ganun pa rin. Ano kaya problema nung oto? 96 honda civic lxi nga pala ride ko mga boss. Pls help naman nakakafrustrate eh.tagal nla ginawa kanina tapos walang nangyari.ty!
- Mar 2007
- 44
January 9th, 2010 10:46 AM #2ano po bang ibig nyong sabihin sa palyado?
namamatay po ba ito ng kusa?
my hesitation sa pag accelerate?
my check engine light po ba? etc....
mas okai po ata pag mas maging specific kyo with the problem.
check niyo po timing ng car niyo.
also your sparkplugs, bka po kelangan nang mapalitan.
- Apr 2009
- 1,902
- Apr 2009
- 1,902
January 9th, 2010 12:24 PM #4I know someone who drives a matic LXi with a similar problem. He found out it was with the torque converter.
Similar symptoms to sliding clutch yata pag manual trans.
Although Im not sure what kind of "palya" is being described here.
Well, you cant start from a basic tune-up, change of spark plugs and air filter element if not done yet.
Or if you've recently had an engine wash, baka nabasa yung loob ng distributor cap at na-grounded na ang isa sa mga spark plugs niyo po.
- Apr 2009
- 1,902
January 9th, 2010 12:27 PM #5Please be specific and describe the "palya" you are referring to.
Engine hesitation? With aircon on?
- Sep 2009
- 15
January 9th, 2010 02:22 PM #6Mga sir thanks sa reply nyo. Manual po gamit ko. Just replaced sparkplugs last august. Pinacheck ko na rin kahapon kung ok pa sparkplugs, ok pa naman. Hindi rin ako nagpa engine wash kaya im sure na hindi nabasa distributor ko... Hindi naman kusang namamatay ung engine. Pag nakahinto then ni-rev mo, parang na cho-choke sya. Pag umaandar ganun din. Di siya maka-arangkada ng maayos. Kahit on or off yun aircon, ganon pa din. Pero mas ramdam yun palya pag naka-on.
- Sep 2006
- 43
January 10th, 2010 08:19 PM #8
Symptoms rin ang High tension wire cable and also check your engine timing .
January 10th, 2010 08:21 PM #9
Symptom rin pag palyado high tension wire set at check your engine timing.
- Sep 2009
- 15
January 10th, 2010 08:37 PM #10Thanks mga paps ha. Nakalimutan ko sabhin na anadjust na rn ung timing nung oto.pero d pa rin ok. Cguro pacheck ko sa electrical pra matignan ung high tension wires. Hopefully maayos na bukas. Salamat po
Not sure if I agree with Caco on this one. At 1.25M the XL7 is overpriced and under-equipped...
2023 Suzuki XL7 Hybrid
