Results 1 to 10 of 12
November 10th, 2005 12:38 AM #1
Hi there fellow chikoteers! (tama ba?)
When I go back to Philippines in a few months I plan to buy a 1999 - 2000 Civic LXi or VTi because I have seen and heard some good reviews on it. Admittedly, I am quite naive with respect to cars in general and not finding any good website or the lack of skill in finding one, is not helping either. I have seen some websites but these are for civics from abroad, so I don't know if the information there applies exactly to what we have in Philippines.
I need your assistance and patience guys in finding out the specifications and features of this car.
Specific questions are:
Which among the two has ABS? two-wheel or four-wheel ABS?
Child-lock?
Airbags? Driver and Passenger?
Power side-mirror?
Keyless entry (optional maybe, or aftermarket na lang)?
VTEC? VTEC2? 2-stage? 3-stage vtec? how do i know if VTEC is still functioning?
EFI (tama ba?)
front disc brakes?
Is there a localized (Philippines-based para akma sa environment natin) review of these cars that you guys can recommend?
How does it compare to a same year corolla gli with respect to the features and amenities?
How is it comparatively more expensive to maintain than that of corollas (I have seen from tsikot forums that parts are quite expensive)?
Thank you in advance to any help you could extend to me, in this regard.
You all have a good day!
November 10th, 2005 01:45 AM #2
AFAIK, 2000 VTi in the Philippines is equivalent to USDM's EX trim.
4-wheel ABS
SOHC VTEC EFI
Power Mirrors, doorlocks, windows
front disc and rear drum
airbags front passenger and driver
pero tulog pa mga tao sa Pinas kaya ala pang reply. but that should give you an idea on the specs.
November 10th, 2005 01:51 AM #3
I found a poll ay back then, maybe it could help you on your decision
http://tsikot.yehey.com/forums/showt...&highlight=VTi
November 10th, 2005 02:30 AM #4
Originally Posted by Karding
Thanks, Karding. I will check the US Civic DX model for the same year.
November 10th, 2005 02:43 AM #5
Hi there fellow tsikoteers! (tama ba?)
I'm afraid none of the 99-00 Civics in the Philippines has ABS.
Child-lock?
Standard equipment on both models
No airbags on any model at all.
Power side-mirror?
VTi only
It's optional equipment you can buy at any accessories shop.
In the VTi, it only states VTEC. I'm not sure if it's VTEC 1 or VTEC 2 though. VTEC helps make the engine more economical with fuel when driving slowly. The engine consumes minimal fuel up until 3000 rpm. The performance side of the VTEC can be experienced above that rev range. Generally, it's somewhat like a 2-in-1 engine - performance when needed but efficient when driven slowly.
EFI (tama ba?)
It's fuel injected, but Honda calls their system PGM-FI (Programmed Fuel Injection.
front disc brakes?
All Civics have front discs
Local car magazines are not yet that famous during the time of this car, although Top Gear features a used car every month (I'm not sure which issue they reviewed this car, but they did).
Unfortunately, the Civic is no match to the Corolla in this aspect. The latter had a driver's airbag, split-folding rear seats and ABS in later models. The Civic, however, somehow makes up through a more advanced engine, more attractive design and better interior space.
A Corolla is generally cheaper and easier to maintain than a Civic. Aside from parts being less expensive and available in almost every auto supply shop in the country, the Corolla's suspension is much sturdier; really made for our bad roads. The Civic has a softer ride and theoretically better handling because of double wishbones front/independent rear suspension (compared to ordinary strut front/beam axle rear for the Corolla), but it's not as durable. You also cannot adjust the camber of the front wheels (as in adjusting the suspension such that the tires are evenly planted on the road). This also means premature tire wear on the inside from the Civic. You can buy aftermarket camber kits but these cost around 10,000 pesos or so. As for Civic parts, there are aftermarket replacement ones available, but based on my experience, they get destroyed much more easily than the original ones, and tend to end up spending more.
You're welcome. I hope I've helped you enough there
Yeah, you too.Last edited by squala; November 10th, 2005 at 03:41 AM.
November 10th, 2005 03:06 AM #8
Sir squala, thank you so much for taking the time and effort to answer my questions. You have been very helpful!
November 10th, 2005 11:40 PM #9
Sir Squala, considering all factors of owning and maintaining a used car of either year '99 or '00, would you recommend against civic as compared to corolla?
To the owners of Civics, how much expensive are functionally equivalent parts of your cars compared to say corolla? Would you agree of a ballpark figure of 10-20% more expensive than corolla parts? I guess I just wanted to gauge if I can maintain it reasonably well within my reach.
:sigh: It would be fun to own a new car but for me it is simply beyond me to be tied with bonds from a bank or something.
Guys, feel free to drop in with your comments and suggestions.
November 11th, 2005 01:24 AM #10
AFAIK, dont expect any performance from a SOHC VTEC. Its tuned for fuel efficiency. On the other hand, DOHC VTEC is performance oriented.
Otherwise, it should be a reliable car.
You also cannot adjust the camber of the front wheels (as in adjusting the suspension such that the tires are evenly planted on the road). This also means premature tire wear on the inside from the Civic. You can buy aftermarket camber kits but these cost around 10,000 pesos or so.Last edited by Karding; November 11th, 2005 at 01:29 AM.
For a 7-seater under 1 million, the Suzuki Ertiga is definitely one of the best options — it’s...
Best car worth 1million and below
