Results 1 to 1 of 1
- Aug 2010
- 86
November 12th, 2010 12:17 AM #1Hi Sirs,
Pa tulong naman. Nawala ang busina ko. After checking, ok naman mga horn at yung relay. Yung coil sa may steering wheel ang may nakita na tanggal na connections yung parang ribbon cable. Try na i-resolder pero after 1 day, wala na naman busina. Malamang tanggal na naman. May surplus ba nung assembly nito? O pwede kayang i-modify na lang ng after market parts para i-fit dito.
Ask ako sa Honda, around 8T daw and assembly nito...
How much room do you have between the battery terminals and the hood seeing the the 3SM is much...
