Results 11 to 20 of 22
December 31st, 2017 07:51 PM #11
Your choice if you want it glass coated. It spares you the hassle of having it waxed regularly, although you'll still need regular car washes.
Say you get glass coating that lasts 2 years, that will set you back around 8-10k.
If you get your car waxed every other month for 300 pesos, that's just 3.6k for 2 years. Which is why I haven't gotten my car coated.
- Jul 2009
- 3,604
December 31st, 2017 08:06 PM #12Malaki ba yung diff ng glass coating? Is it like perma wax that needs car wash?
When I had (marginally) more time, I used to have the car waxed every month or so.
The last time our cars have had a wax is probably mga 3-4 years ago hehehehe
Might consider glass coating kung ganun para one shot lang
- Dec 2017
- 1,018
December 31st, 2017 10:46 PM #13Ceramic coat/Glass coating whatever they call it are still prone to scratches, swirl marks, rock chips and water spots. Don't believe the marketing hype stating that it's scratch proof and what not. Think of it as another layer of super glossy "clear coat" on your car. Yes, your car will look fantastic as it brings it to another level of gloss. Every one will notice it.
Don't believe those YouTube videos where they throw mud water on the car and it will just glide without sticking to your car. It's B.S. What's that? Non stick Teflon? Lol. Mud, dirt, asphalt, bugs, tree sap and grime will still stick to your car. It's only hydrophobic and not mud-o-phobic. Lol.
If you want another layer of "clear coat" to preserve the original factory clear coat, then go for it. At least when you buff out a scratch or swirl marks, you know you're buffing the "ceramic" layer only. It will also save you 2 yrs worth of waxing.
- Sep 2006
- 2,746
January 1st, 2018 10:02 AM #14
- Sep 2006
- 2,746
January 1st, 2018 07:18 PM #15Thanks sir mda and brushless for the share
- May 2017
- 572
January 1st, 2018 10:10 PM #16Because it's really not mud but just colored water. Hehe
I also prefer waxing as it helps you keep a consistent protection level for your car as oppose to a waning/deteriorating one. Same reason why I'm not enticed by the super long lasting waxes that are promoted in the net.
Equally important will be how you wash your car.... Use the right materials/methods and wash it at least once a week when it rains to avoid watermarks from bonding your paint and glass.
- Sep 2017
- 64
January 2nd, 2018 10:58 AM #17Thank you sir Jut! Saw your previous posts before about sa Civic and that made me finalize my choice. So rims nalang muna? Im planning on getting the quad tip exhaust, spoiler, drl leds rear and frond and chin too. Iniisip ko kasi sa rims hindi kaya bababa ground clearance ko if I choose an 18” rims and tires? Also, howd you get that grille black? Pinagawa mo or what? Diba babagal sasakyan nun kasi youll be adding weight kasi bigger rims?
- Sep 2017
- 64
January 2nd, 2018 11:00 AM #18Re glass coat, diamond coat, ceramic coat, titanium coat etc. nag iisip din ako ipaganyan kasi sa mga vids nila sa fb talagang eye catching. Inooven pa nga hehe! Well, atleast nag ka idea ko kung pano ba talaga ginagawa and effect nun. Thank you all sa feedback!!
- Jul 2009
- 3,604
January 2nd, 2018 11:07 AM #19Some unsolicited inputs:
1. Quad Tip Exhaust - you will need to spend extra to modify/build a new bumper that looks integrated with this. Also IMO medyo baduy. Compact car / 1.8L tapos quad tip. Even the Type-R only has 3 exhaust tips hehehe.
2. Spoiler - Ok your choice. Hopefully you don't overdo it lang.
3. DRL Led Front Chin and Rear - Probably one max. Medyo baduy din pag tinadtad. Parang yung chrome trimmings, one or two chrome accents may be okay. Pero pag lahat ng pwede mong lagyan, nilagyan, panget na.
4. Rims - if the total diameter of your new rims and your old rims are almost the same, will not affect your ground clearance and will not rub against the fender. Example: 16" rims + tires that add 4" to the rim+tire diameter = 20" diameter. 18" rims + tires that add 2" to the rim+tire diameter = 20" diameter you'll end up with the same stance.
5. Black grille - many ways to do it depending on your budget. Yung kay sir Jut, pinapintura yan. Other ways: 1 - Plasti Dip. 2 - Buy an RS grille brand new or 2nd hand.
6. Re: Babagal sasakyan - yes may impact on acceleration and fuel consumption IF malayo yung weight difference. Go weigh your original set nalang and the new set if praning ka dito. If you replace your rims with a set original Volk TE37s, you will reduce your wheel weight by around 50% if I'm not mistaken... :DLast edited by mda; January 2nd, 2018 at 11:10 AM.
January 2nd, 2018 11:07 AM #20
Ground clearance is the same because overall tire circumference is the same. With my current set of wheels, I don't scrape humps and ramps and have never needed to tackle them sideways like what lowered cars do.
I had my grille painted black. You can also order a new set of black grilles for around 6k. Painting is cheaper, just around 2k.
It's your money so you can do whatever mods you like, but if I may share my thoughts:
Quad tip - very ricey, very poser unless you change your whole exhaust system and not just add fake tailpipes. Doesn't bode well with the 1.8 either which isn't much of a performance car at all.
LED DRL - what for? The car already comes with an OEM DRL up front and LED tail lamps at the back.
Chin/skirts - looks off if your car isn't lowered. Before adding additional body kit, get lowering springs first.
Again, your car, your rules. Subtlely is classy but you can go bonkers if that's what makes you happy.
Could also be due to the high demand that the manufacturer prioritized new car deliveries vs. spare...
BYD Sealion 6 DM-i
