Results 561 to 570 of 936
September 5th, 2017 09:30 AM #561
If you opt for semi synth and no extra for your PMS, nasa 3,800 lang yang 10K pms.
Using 91RON Total as well / sometimes Unioil, getting 6.5 to 7 kms per liter, mandaluyong - makati - mandaluyong - espana - mandaluyong
- Jun 2017
- 19
September 5th, 2017 09:55 AM #562
- Sep 2017
- 6
September 6th, 2017 08:14 PM #563Sirs this will be my first car. Im confused prin hangang ngaun which one should i buy since this will be financed. Innova 2.8G or BRV TOTL. Thanks for the reply sirs
September 6th, 2017 08:28 PM #564
Do you need the higher ground clearance? If so, then Innova na. Much livable 3rd row pa if you need it.
- Feb 2014
- 2,694
September 6th, 2017 09:32 PM #565
first off, BRV is CVT only which doesn't have the track record yet. it was only reintroduced in 2014. their earlier attempt at CVT (city and jazz GD) wasn't so reliable for long-term use (like 10years)
that said BRV does look OK and is quite spacious considering that it is a small & lighweight car
innova on the other hand has a big and heavy ladder frame but only ends up as a family car (ladder frames are usually on trucks and off-roaders). so you'll be hauling around all that weight everywhere
- 54,188
September 6th, 2017 10:16 PM #566brv is quite spacious, but only considering... sa totoo lang, i find the inside, cramped.
innova is quite spacious. period. no ifs, no buts.
transmission? innova's presumably beefier MT or AT promise to be more reliable than brv's trans.
so what if it's ladder frame and heavy? innova diesel still trumps brv, fuel expense-wise.
if larger external measurements are not an issue with you, i'd recommend innova.
- Sep 2017
- 6
September 6th, 2017 10:30 PM #567Thanks for the reply sir vodka. Actually no idea ko.pgdtng sa trans ng brv. Buti na lang po nabigyan niyo ko ng info. about jan. Toyota innova,no problem with the external features for me though the price is a bit higher than TOTL brv, pero if it will last for lets say 10 years, why not right?not a bad investment after all. Anyway sir, Salamat po ng Marami.
- Sep 2017
- 6
September 6th, 2017 10:34 PM #568
- Feb 2014
- 2,694
September 6th, 2017 10:38 PM #569
well mahirap umakyat ang senior citizens sa innova which is a shame coz its supposed to be a family car. blame the ladder framekung monocoque yan walang problema. but that's just theoretical coz monocoque innova doesn't exist. and yes a monocoque innova would be more fuel efficient, almost as good as BRV diesel which isn't sold here
in short what i said was just theoretical
- Sep 2017
- 6
September 6th, 2017 10:40 PM #570
If purely for City driving then get the Emax7. since you already have other cars for longer drives....
BYD Sealion 6 DM-i
