Results 1 to 10 of 16
- Nov 2009
- 3
May 6th, 2012 02:33 AM #1im planning to put a grounding kit on my eg hatch even he runs well, will grounding kit still improves its performance?
May 9th, 2012 04:44 PM #2
aftermarket grounding kits are unnecessary. if the original wiring harness is not damaged or corroded, there should be no need to install one. this only adds to the vehicle weight and decrease the mpg rating of the car. if you can measure the difference in the ground circuit of any load against the negative post of the battery and it does not exceed 0.2 volts of drop in the ground, the original must be sufficient.
May 9th, 2012 07:06 PM #4
From my experience yes, kung tama pag lagay ng ground mo & EFI sya, in my case it improve the response in throttle & Automatic transmission, mapapansin mo din mas maliwanag ilaw mo.
- Apr 2012
- 94
May 10th, 2012 10:52 PM #7
May 11th, 2012 01:00 PM #8
Please read my post carefully, I didnt say 'HP' i said 'improvement' because it has nothing more to gain unless you upgrade the engine or the ECU. Grounding kit improves the flow of current, especially if you have an old car, lumalabo connection habang tumatagal so grounding kits just improves the flow.
May 11th, 2012 01:05 PM #9
Hindi lang porma yan, My auto electrician once said, it is a simple, cheap way to improve electrical efficiency on your car, lalo na pag old car, kung mapapansin nyo bkt nyo kailangan linisin terminal ng battery nyo? because pag nagkaroon ng buildup ng carbons or calcium, humuhina current and EFI loves current.
May 11th, 2012 01:34 PM #10
Actually, grounding kits are more useful on cars that have moderate to powerful sound setups or other high-current accessories. It's physics that the thicker the conductor, the better the conductivity and hence, the voltage drop is lower.
However, the law of diminishing returns apply to this mod as well. A good designer would only use "as much" AWG as the load requires at peak.
Toyota Sports 800 (1965 - 1969) behind the man at the start of the video. :nod: I wish car...
2025 Manila International Auto Show
