Results 231 to 240 of 255
- Jul 2007
- 6
March 19th, 2016 11:53 PM #231
- Mar 2016
- 3
March 20th, 2016 03:30 PM #232honda jazz 2005. 1.3 IDSI....The car is a very smooth drive indeed, wala jerk or judder..malakas humatak sa drive(D) pero pag dating sa highway ko nararamdaman.. mahina apak mo going to 80km * 2.5 rpm but after sa tollgate sa nichols mag accelerate na, napapansin ko nag high rpm na sya.. same apak din naman...going to 80km * 3.5rpm na... then medyo bibitawan ko gas pedal.. ayaw na bumaba ng rpm.. para kang nasa 3rd gear lang ng AT.. dapat nasa 7th gear na.. so inaactivate ko nalang yung 7speed mode para bumaba yung RPM at 80km... pero pag deneactivate mo yung 7 speed mode biglang tataas uli yung RPM 3.5...ano kaya problem? na calibrate ko na CVT, changed CVTF..thanks
March 28th, 2016 06:26 PM #233
- Jul 2012
- 329
- Sep 2016
- 3
- Sep 2016
- 3
September 20th, 2016 10:09 AM #236Mga ka tsikot, good am.
Related ba sa ignition coil tong na experience ko,
If babyahe ako like short km pa galing sa house namin then once mag s-stop ako either stop light or traffic, biglang mag jolts/kick ung car ko then ung RPM biglang mag random (vibration din; using A/C or not), from 400- 1k, then balik sa dati. Mostly na experience ko to during morning or ung galing pa sa cold engine..
Once makaka ilang km na ako like 20km+, mawawala na ung problem during mag s-stop, pero nakakatrauma
Honda fit surplus 2008 model
salamat ka tsikot- newbie lng po
DONE with TB cleaning - using carb cleaner. Changed new air filter.
New tranny - almost 1 yr used
Sabi ng erpats ko hinaloan daw ng maliit ung CVT fluid ko ng National brand ATF - makaka apekto ba yun?
Newly changed oil and filter (kaso exist pa din ung prob)
September 20th, 2016 11:03 AM #237
Tsikot Member Rank 3
- Nov 2002
- 1,981
October 12th, 2016 10:38 PM #238Mga sirs.
Question lang. i have a local GD 2005 1.3 idsi jazz cvt. may problem yung oxygen sensor as per casa diagnosis which they say has to be replaced. its supposedly the rear oxygen sensor 2.
Do you know any place to find a cheaper, surplus alternative to replace it?
i have searched at Evangelista street and in Pasay area and puro original lang binigay sa akin. wala daw surplus. even the surplus shop wala.
prefer sana if its inn the makati/pasay/bgc area.
thanks
- Apr 2017
- 1
April 14th, 2017 12:46 PM #239Good day tsikot! Mga sir may naka experience na ba sa inyo na nag loloko ang idle pag nag mamatic ang AC compressor. Akyat ng 1.5k rpm at baba ng 500rpm hanggang mahanap niya yung tamang idle. Nangyayari madalas pag tanghali at traffic, pag gabi at traffic ok naman.
- 54,197
April 14th, 2017 01:04 PM #240most cars have an automatic "idle up" controller, precisely for that.
when the aircon compressor kicks in, the engine rpm goes down. when the compressor shuts down, the engine rpm goes up. the idle up controller automatically ups and downs the rpm to compensate.
some controllers are simple electro-mechanical things, while others are integrated into the car's computer.
bring your car to a qualified mechanic, someone who knows what he's doing.
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
