Page 23 of 26 FirstFirst ... 131920212223242526 LastLast
Results 221 to 230 of 255
    #221
    Quote Originally Posted by nashimoto View Post
    Mga sir jazz gd ko napalitan na main oil seal, ni reseal na oil pan at palit top valve gasket pero may nakkita patin ako konting leaks sa ilalim ng car.. Anu kaya un?
    oilpan seal... oil drain plug seal..
    distributor oil seal (your car does have a distributor, yes?).
    main crankshaft oil seals (ugh!).
    baka rin, medyo maluwag ang pagkabit ng mga turnilyo..
    puede ring butal na lang yan ng natapong langis nung ginawa.. punasan nyo po and see if it leaks again..
    Jul 2011
    #222
    Quote Originally Posted by majeogo View Post
    Hi there, I‘m currently considering buying a used Jazz
    Have enough cash for a either a GD or a GE
    I do wanna save some cash so I am leaning on to the GD more
    Question is, is the GD still a good buy despite its age?
    TIA :-)
    Depende sa condition, if the previous owner maingat naman sa kotse,
    it still is a good buy, may it be GD or GE, pero syempre, mas okei ang newer GE model.
    Quote Originally Posted by b16sir_stock View Post
    Manual 1.3
    Problems :
    1. Experiencing slight jerking when accelerating (unang tapak ng gas) for 1st to 2nd or sometimes 3rd gear.
    2. On very long traffic (e.g. idle more than 15 mins) the idling will suddenly increase up to 2+ rpm and
    mawala lamig ng aircon. If I turn of the aircon everything will be ok. Need to open again aircon after normal
    cruising otherwise babalik uli problem.
    1. I felt the same before on my GD, its my clutch slipping.
    2. pacheck mo nalang sir sa mga A/C shop, usually free estimate naman sila.
    best if you have the car underwashed, and observe, malalaman mo na kung saan source ng leak,
    flywheel oil seal, crankshaft oil seal, yan yung mga oil seal sa magkabilang side.
    or as dr.d's reply, oil drain plug, baka hindi mahigpit
    GDs have coil packs already, wala na distributor sir.
    Jul 2012
    #223
    Sir questin.. Nid ko mgpalit condenser fan motor.. Hindi na kasi umiikot fan not unless itulak muna ng daliri.. Parang lumang electricfan na ayaw umikot unles paikutin muna ng kamay. 6k ang qoute orig denso.. 1. 4k circuit brand. Ok lang ba mg circuit?
    May 2015
    #224
    Ok din circuit brand, yan din ginamit ko before sa 1st Gen CRV, wala naman naging problema.
    Dec 2007
    #225
    Quote Originally Posted by 7138 View Post
    thanks though hindi kaya sa ignition coil? saan kaya pwede magpacheck ng ignition coil?
    Jul 2012
    #226
    Quote Originally Posted by norelco View Post
    thanks sir.. ok na fan ko.. sana tumagal buhay ng circuit motor
    Jul 2012
    #227
    jazz GD ko minsan pag nag bbreak ako or idle or paandar pa lang nanginginig.. kadalasan kapag bukas aircon. sumasabay kaya yung nginig sa pag ikot ng fans? ignition coils kaya? pinalitan ko na lahat kaso replacement lang.. hindi naman nagloloko rpm ko pag idle ako.. nsa halos 700rpm ko.. tranny was already replaced from japan surplus, spark plugs bago din.
    May 2015
    #228
    Check engine support
    Dec 2007
    #229
    ok naman na yun idling now but left with the problem on jerking.
    napalitan na ng 2 coil pack and spark plugs ganun parin jerking parin.
    Any recommended shop na ma solve problem ko and even scan maybe
    the comp box for troubles?
    Dec 2007
    #230
    finally solve my car jerking problems after another shop scan it comp box.
    error was TP Sensor (Voltage Low)... they adjusted it and now its fixed...
First Gen Honda Jazz/Fit (GD) discussion
