Page 22 of 26 FirstFirst ... 12181920212223242526 LastLast
Results 211 to 220 of 255
    #211
    Meron ako City 2008 MT, bigla lang nag ilaw yung EPS sa dash tapos mabigat iliko. Nag chk ako ng fuse buo naman. Ano kaya sira at kailangang ipagawa? Salamat po.
    Jul 2012
    #212
    mga sir palitin po ba tlga ang thermostat ng honda jazz 2005 1.5vtec matic? hindi po kasi nag on rad fan kapag patay aircon eh..
    Dec 2007
    #213
    Quote Originally Posted by nalubmis View Post
    Mga sir bat kaya ganon yng jazz ko pag nag drive ako tpos reverse tpos balik ulit sa drive parang nanginginig.. AT jazz ko. sa engine support kaya yun?
    pa change ka sir ng atf.
    Jul 2012
    #214
    make sure orig CVTF gamitin mo ha
    Aug 2015
    #215
    Hi there, I‘m currently considering buying a used Jazz
    Have enough cash for a either a GD or a GE
    I do wanna save some cash so I am leaning on to the GD more
    Question is, is the GD still a good buy despite its age?
    TIA :-)
    Aug 2015
    #216
    Mag paps, need ur help/opinion and advise. Ano po kya problema ng Jazz GD ko, may maingay don sa rear right na gulong pag napadaan sa kahit konti slope lalo na hi-way at kung may passenger sa back. Parang may sumasayad.. Need q tuloy mag menor..
    TIA...c",)
    #217
    Quote Originally Posted by R_B1129 View Post
    TIA...c",)
    it is obvious that a mechanic should see it. dalhin nyo na po sa mekaniko. mahirap magbigay ng payo nang ni hindi man lang nakikita.
    but my suspicions include may sumasayad nga.. baka yung wheel well rubber, kung meron.. baka yung rubber bushings ay dapat nang palitan.. baka yung bearing ay pulbos na.. baka yung gulong mismo ay sumasayad na sa katawan!! maraming puede..
    good luck.
    Aug 2012
    #218
    A little info about Honda's Fully Synthetic Engine Oil
    The Layman Auto: What's with 0W-20 synthentic lubricant and will it last?
    http://laymanauto.blogspot.com/2014/06/whats-with-0w-20-synthentic-lubricant.html
    Dec 2007
    #219
    Manual 1.3
    Problems :
    1. Experiencing slight jerking when accelerating (unang tapak ng gas) for 1st to 2nd or sometimes 3rd gear.
    2. On very long traffic (e.g. idle more than 15 mins) the idling will suddenly increase up to 2+ rpm and
    mawala lamig ng aircon. If I turn of the aircon everything will be ok. Need to open again aircon after normal
    cruising otherwise babalik uli problem.
    Jul 2012
    #220
    Mga sir jazz gd ko napalitan na main oil seal, ni reseal na oil pan at palit top valve gasket pero may nakkita patin ako konting leaks sa ilalim ng car.. Anu kaya un?
First Gen Honda Jazz/Fit (GD) discussion
