Page 24 of 26 FirstFirst ... 1420212223242526 LastLast
Results 231 to 240 of 255
    #231
    Quote Originally Posted by b16sir_stock View Post
    finally solve my car jerking problems after another shop scan it comp box.
    error was TP Sensor (Voltage Low)... they adjusted it and now its fixed...
    Sir, saan shop nyo pina scan and adjust TPS
    Thanks
    Mar 2016
    #232
    honda jazz 2005. 1.3 IDSI....The car is a very smooth drive indeed, wala jerk or judder..malakas humatak sa drive(D) pero pag dating sa highway ko nararamdaman.. mahina apak mo going to 80km * 2.5 rpm but after sa tollgate sa nichols mag accelerate na, napapansin ko nag high rpm na sya.. same apak din naman...going to 80km * 3.5rpm na... then medyo bibitawan ko gas pedal.. ayaw na bumaba ng rpm.. para kang nasa 3rd gear lang ng AT.. dapat nasa 7th gear na.. so inaactivate ko nalang yung 7speed mode para bumaba yung RPM at 80km... pero pag deneactivate mo yung 7 speed mode biglang tataas uli yung RPM 3.5...ano kaya problem? na calibrate ko na CVT, changed CVTF..thanks
    Dec 2007
    #233
    Quote Originally Posted by junrl View Post
    Thanks
    A.L Auto Parts sa may abad santos near tayuman intersection.
    Jul 2012
    #234
    Mga sir anu OBD2 protocol ng Honda jazz 2005 (GD) natin? Thanks!
    Sep 2016
    #235
    Quote Originally Posted by damulag1 View Post
    Tranny problem ata to boss.
    Sep 2016
    #236
    Mga ka tsikot, good am.
    Related ba sa ignition coil tong na experience ko,
    If babyahe ako like short km pa galing sa house namin then once mag s-stop ako either stop light or traffic, biglang mag jolts/kick ung car ko then ung RPM biglang mag random (vibration din; using A/C or not), from 400- 1k, then balik sa dati. Mostly na experience ko to during morning or ung galing pa sa cold engine..
    Once makaka ilang km na ako like 20km+, mawawala na ung problem during mag s-stop, pero nakakatrauma
    Honda fit surplus 2008 model
    salamat ka tsikot- newbie lng po
    DONE with TB cleaning - using carb cleaner. Changed new air filter.
    New tranny - almost 1 yr used
    Sabi ng erpats ko hinaloan daw ng maliit ung CVT fluid ko ng National brand ATF - makaka apekto ba yun?
    Newly changed oil and filter (kaso exist pa din ung prob)
    #237
    Quote Originally Posted by nashimoto View Post
    Sir, nabasa ko sa fitfreak na may nabili ka nang OBD2.
    May link ka ba? Dami kasi sa lazada e.
    Thanks
    #238
    Mga sirs.
    Question lang. i have a local GD 2005 1.3 idsi jazz cvt. may problem yung oxygen sensor as per casa diagnosis which they say has to be replaced. its supposedly the rear oxygen sensor 2.
    Do you know any place to find a cheaper, surplus alternative to replace it?
    i have searched at Evangelista street and in Pasay area and puro original lang binigay sa akin. wala daw surplus. even the surplus shop wala.
    prefer sana if its inn the makati/pasay/bgc area.
    thanks
    Apr 2017
    #239
    Good day tsikot! Mga sir may naka experience na ba sa inyo na nag loloko ang idle pag nag mamatic ang AC compressor. Akyat ng 1.5k rpm at baba ng 500rpm hanggang mahanap niya yung tamang idle. Nangyayari madalas pag tanghali at traffic, pag gabi at traffic ok naman.
    #240
    Quote Originally Posted by Olrac29 View Post
    most cars have an automatic "idle up" controller, precisely for that.
    when the aircon compressor kicks in, the engine rpm goes down. when the compressor shuts down, the engine rpm goes up. the idle up controller automatically ups and downs the rpm to compensate.
    some controllers are simple electro-mechanical things, while others are integrated into the car's computer.
    bring your car to a qualified mechanic, someone who knows what he's doing.
First Gen Honda Jazz/Fit (GD) discussion
