Results 221 to 230 of 255
- 54,198
January 18th, 2016 11:28 PM #221oilpan seal... oil drain plug seal..
distributor oil seal (your car does have a distributor, yes?).
main crankshaft oil seals (ugh!).
baka rin, medyo maluwag ang pagkabit ng mga turnilyo..
puede ring butal na lang yan ng natapong langis nung ginawa.. punasan nyo po and see if it leaks again..
January 21st, 2016 10:07 AM #222
Depende sa condition, if the previous owner maingat naman sa kotse,
it still is a good buy, may it be GD or GE, pero syempre, mas okei ang newer GE model.
1. I felt the same before on my GD, its my clutch slipping.
2. pacheck mo nalang sir sa mga A/C shop, usually free estimate naman sila.
best if you have the car underwashed, and observe, malalaman mo na kung saan source ng leak,
flywheel oil seal, crankshaft oil seal, yan yung mga oil seal sa magkabilang side.
or as dr.d's reply, oil drain plug, baka hindi mahigpit
GDs have coil packs already, wala na distributor sir.
- Jul 2012
- 329
February 1st, 2016 08:44 PM #223Sir questin.. Nid ko mgpalit condenser fan motor.. Hindi na kasi umiikot fan not unless itulak muna ng daliri.. Parang lumang electricfan na ayaw umikot unles paikutin muna ng kamay. 6k ang qoute orig denso.. 1. 4k circuit brand. Ok lang ba mg circuit?
February 1st, 2016 08:49 PM #224
Ok din circuit brand, yan din ginamit ko before sa 1st Gen CRV, wala naman naging problema.
February 4th, 2016 12:07 PM #225
- Jul 2012
- 329
February 5th, 2016 03:20 AM #226
- Jul 2012
- 329
February 5th, 2016 03:22 AM #227jazz GD ko minsan pag nag bbreak ako or idle or paandar pa lang nanginginig.. kadalasan kapag bukas aircon. sumasabay kaya yung nginig sa pag ikot ng fans? ignition coils kaya? pinalitan ko na lahat kaso replacement lang.. hindi naman nagloloko rpm ko pag idle ako.. nsa halos 700rpm ko.. tranny was already replaced from japan surplus, spark plugs bago din.
February 5th, 2016 02:54 PM #228
February 15th, 2016 08:58 AM #229
February 22nd, 2016 09:08 AM #230
finally solve my car jerking problems after another shop scan it comp box.
error was TP Sensor (Voltage Low)... they adjusted it and now its fixed...
One can only hope.
